Hi all, just looking for some advice, i don't really know this car too well yet.
I've had a 2005 Audi A3 2.0 TDI since May this year, 61,000miles on it.
Had the engine management light come on a few weeks back, Vagcom'd it and told me:
1 Fault Found:
16567 - Fuel Temp. Sensor A (G81)
P0183 - 000 - Open or Short to Plus - Intermittent
Freeze Frame:
RPM: 756 /min
Torque: 54.0 Nm
Speed: 13.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Temperature: 23.4°C
Temperature: 38.7°C
Temperature: -37.8°C
Bought the new part, fitted it and cleared the code. All sorted.
Then the last couple of days the light come back on and also can't turn the air con on (ECON) button stays lit up.
Scanned it tonight and got:
3 Faults Found:
19557 - Motor for Intake Manifold Flap (V157)
P3101 - 000 - Open or Short to Ground
Freeze Frame:
RPM: 1155 /min
Torque: 130.0 Nm
Speed: 26.0 km/h
Load: 26.3 %
Voltage: 14.14 V
Bin. Bits: 11000100
Torque: 168.0 Nm
Torque: 140.0 Nm
17075 - Fan 1 Control Circuit
P0691 - 000 - Short to GND
Freeze Frame:
RPM: 1260 /min
Torque: 0.0 Nm
Speed: 34.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Bin. Bits: 11000011
Temperature: 86.4°C
Duty Cycle: 9.6 %
19558 - Motor for Intake Manifold Flap (V157)
P3102 - 000 - No Signal
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 00000100
Torque: 0.0 Nm
Torque: 354.0 Nm
Readiness: 1 2 0 0 0
Closed bonnet and did something else instead.
Car seems to drive fine, used to be a bit juddery in the morning before the fuel temp sender and that's gone away. I do notice that after a journey and turning engine off it seems to shut off with quite a jump, bit more sudden than it was (a bit like if you stall it). Could it be an earth issue?
All i could see under bonnet that caught my eye was a very small amount of oil around the turbo, seems to blow a bit onto the alternator.
1 Fault Found:
Freeze Frame:
RPM: 756 /min
Torque: 54.0 Nm
Speed: 13.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Temperature: 23.4°C
Temperature: 38.7°C
3 Faults Found:
Freeze Frame:
RPM: 1155 /min
Torque: 130.0 Nm
Speed: 26.0 km/h
Load: 26.3 %
Voltage: 14.14 V
Bin. Bits: 11000100
Torque: 168.0 Nm
Torque: 140.0 Nm
Freeze Frame:
RPM: 1260 /min
Torque: 0.0 Nm
Speed: 34.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Bin. Bits: 11000011
Temperature: 86.4°C
Duty Cycle: 9.6 %
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 00000100
Torque: 0.0 Nm
Torque: 354.0 Nm
