mode button on mfsw not working after retrofit
wigandill
Hi
I have recently fitted a mfsw and cruise to my a4 b7 to go along with my rns-e and audi bluetooth, everything on the mfsw works fine except the mode button, when its pressed i beleive it should show my phone book and radio information on the dis but it does nothing, is there anything that needs to be done to enable this feature, both scroll wheels work as should, and the voice feature also works (apart from the mic not being wired into the rns-e yet) as it comes wit with all the diffrent help options for radio, nav, phone ect after it says pardon.
we beleive evetything is coded correctly but i didnt personaly code it myself
Any advice would be great
Get an autoscan of your car and we can digest from that what has been coded and anything that's been forgotten.
Hi buddy what was the part number of the control module you used ?
Did you even have to change the module ?
What parts did you use for the conversion ?
I'm doing this myself and have the mfsw , airbag wiring harness for the mfsw and just can't seem to get it to work.
Don't mean to hijack your post mate just wondering
Thanks a lot Dan
Have you coded all 3 components ?
Tel 77
Nav 36
Steering 17
Will all need coding correctly
My auto electrician has tried be no luck have code 00466 control module for steering column electronics ( j527 ) no communication
Like I said I have the steering wheels with multi function , airbag loom and the control module with this part number , not really sure why it ain't working unless I need to go to Audi to get it coded ? Been told this module should work
Thanks for reply if it was for me lol
Dan
The module you have is the correct highline module
Yes it will Deffo require coding with vcds
I've looked at my slip ring today and it's a 6 pin one am I right in saying I need the 12 pin slip ring for all this to mesh together and work ? If I do is there another wiring harness I need as well for it to work or will those extra pins be in the L peice on the back that goes into the module? Sorry for the million questions mate !!
Thanks again
Thank you very much for taking time out to help me I really appriciate it !! Picking up new slip ring sat and will get it on Vag com and get it sorted !
Were you getting slip rig from a d how much? This is what i need for mine, and dnt fancy ordering the cheap chinese one from ebay lol
Hi buddy I'm getting mine tomorrow from Nirro they are a Vag breakers in barking Essex they send too ! I've delt with them before and they are clued up !
I'm paying £60 for my slip ring and I'm driving up to get it so if they send yours expect a little p&p
The part is genuine too , brand new genuine is over £230 which is a serious amount of £££
Would you like the part number of the slip ring you require ( 12 pin ) ?
Hope this helps
Dan
Should be 4EO 953 541 B
Cool ! I'm off to go get mine now
My 12 pin slip ring all fitted and set up working a treat now , don't know how I coped without it now haha ! thank you all for your help guys !!
Dan
Reactions: Jason owen
Hi,
I’ve just installed an RNS-E and KUFATEC 36431 Audi Basic Plus Bluetooth phone kit into my 2008 Audi A4 convertible. I live in England and with a European RNS-E.
I know that I need to code the RNS-E to the car via the VCDS but I am unsure what the correct codes should be for the RNS-E, multi functional steering wheel and instrument display. Currently the sat Nav instructions do not appear in the instrument cluster and neither the mode or voice control buttons on the multi functional steering wheel work. What does work are both the selection wheels on the steering wheel for volume and track change and when using the phone, the DIS displays phone.
Using the VCDS, the current stored codes are as follows:
Steering wheel 02011
Instrument 0006411 with the number currently stored in the adaption for channel 62 being 17
Radio 0301713
From what I have read in various forums, I believe I need to change the numbers to the following:
Steering wheel 03011
Instrument adaption channel 62 to 21
Radio 0301717
Can someone please validate the correct codes for me please as I think I’ve read every forum page and have not been able to determine the right codes.
