philipposx
Hi all, I have run the VCDS and I got the below results.
Can someone check and let me know what could be faulty and how can I fix this?
I have a mechanic opinion already that says one of the relays on the motor pump is faulty and these are not detachable to be replaced and I have to replace the whole pump.
I appreciate any advice on these.
VCDS-Lite Version: Release 1.2
Sunday, 08 June 2014, 18:45:04.
Control Module Part Number: 8H0 959 255
Component and/or Version: VSG B6 CABRIO 6286
Software Coding: 0000000
Work Shop Code: WSC 00001
VCID: F399DCCFD2AD
1 Fault Found:
02023 - Terminal 87
008 - Implausible Signal - Intermittent
And the LOG file (CSV format) while the button was idle and when I tried to open the roof-top and then released it:
Sunday,08,June,2014,18:47:34
8H0 959 255 ,, VSG B6 CABRIO 6286,
,Group A:,'001,,,,Group B:,'002,,,,Group C:,'003
,,Convertible Top,Switches &&,Switches &&,Top Frame,,Vehicle Speed,Voltage,Rear Lid,Window Regulator,,Window Position,Window Position,Window Position,Window Position
,TIME,Control Switch,Positions I,Positions II,Position (G356),TIME,,(Terminal 30),Contact Switch,Operation,TIME,Driver's Door,Passenger Door,Rear Left Door,Rear Right Door
Marker,STAMP,,,,,STAMP, km/h, V,,,STAMP,,,,
,0.60, Not Oper.,11011010,10 1010,235.0,0.19,0.0,11.70, Lid close,00000000,0.40,100.0,100.0,96.5,95.5
,1.24, Not Oper.,11011010,10 1010,235.0,0.83,0.0,11.70, Lid close,00000000,1.04,100.0,100.0,96.5,95.5
,1.88, Not Oper.,11011010,10 1010,235.0,1.45,0.0,11.70, Lid close,00000000,1.68,100.0,100.0,96.5,95.5
,2.51, Not Oper.,11011010,10 1010,235.0,2.09,0.0,11.70, Lid close,00000000,2.30,100.0,100.0,96.5,95.5
,3.15, Not Oper.,11011010,10 1010,235.0,2.73,0.0,11.70, Lid close,00000000,2.94,100.0,100.0,96.5,95.5
,3.79, Not Oper.,11011010,10 1010,235.0,3.36,0.0,11.70, Lid close,00000000,3.58,100.0,100.0,96.5,95.5
,4.43, Not Oper.,11011010,10 1010,235.0,4.00,0.0,11.70, Lid close,00000000,4.20,100.0,100.0,96.5,95.5
,5.05, Not Oper.,11011010,10 1010,235.0,4.64,0.0,11.70, Lid close,00000000,4.84,100.0,100.0,96.5,95.5
,5.67, Not Oper.,11011010,10 1010,235.0,5.26,0.0,11.70, Lid close,00000000,5.47,100.0,100.0,96.5,95.5
,6.31, Not Oper.,11011010,10 1010,235.0,5.88,0.0,11.70, Lid close,00000000,6.11,100.0,100.0,96.5,95.5
,6.95, Not Oper.,11011010,10 1010,235.0,6.52,0.0,11.70, Lid close,00000000,6.73,100.0,100.0,96.5,95.5
,7.58, Not Oper.,11011010,10 1010,235.0,7.16,0.0,11.70, Lid close,00000000,7.37,100.0,100.0,96.5,95.5
,8.22, Open,11011010,10 1010,235.0,7.80,0.0,11.70, Lid close,00000000,8.01,100.0,100.0,96.5,95.5
,8.86, Open,11011010,10 1010,235.0,8.43,0.0,11.70, Lid close,00000000,8.63,100.0,100.0,96.5,95.5
,9.48, Open,11011010,10 1010,235.0,9.07,0.0,11.70, Lid close,00000000,9.27,100.0,100.0,96.5,95.5
,10.12, Open,11011010,10 1010,235.0,9.71,0.0,11.70, Lid close,00000000,9.91,100.0,100.0,96.5,95.5
,10.76, Open,11011010,10 1010,235.0,10.33,0.0,11.70, Lid close,00000000,10.54,100.0,100.0,96.5,95.5
,11.39, Open,11011010,10 1010,235.0,10.97,0.0,11.70, Lid close,00000000,11.18,100.0,100.0,96.5,95.5
,12.01, Open,11011010,10 1010,235.0,11.59,0.0,11.70, Lid close,00000000,11.80,100.0,100.0,96.5,95.5
,12.65, Open,11011010,10 1010,235.0,12.23,0.0,11.70, Lid close,00000000,12.44,100.0,100.0,96.5,95.5
,13.29, Open,11011010,10 1010,235.0,12.86,0.0,11.70, Lid close,00000000,13.07,100.0,100.0,96.5,95.5
,13.91, Not Oper.,11011010,10 1010,235.0,13.50,0.0,11.70, Lid close,00000000,13.71,100.0,100.0,96.5,95.5
,14.55, Not Oper.,11011010,10 1010,235.0,14.14,0.0,11.70, Lid close,00000000,14.35,100.0,100.0,96.5,95.5
,15.19, Not Oper.,11011010,10 1010,235.0,14.76,0.0,11.70, Lid close,00000000,14.99,100.0,100.0,96.5,95.5
,15.82, Not Oper.,11011010,10 1010,235.0,15.40,0.0,11.70, Lid close,00000000,15.61,100.0,100.0,96.5,95.5
,16.49, Not Oper.,11011010,10 1010,235.0,16.04,0.0,11.70, Lid close,00000000,16.28,100.0,100.0,96.5,95.5
,17.11, Not Oper.,11011010,10 1010,235.0,16.70,0.0,11.70, Lid close,00000000,16.90,100.0,100.0,96.5,95.5
,17.75, Not Oper.,11011010,10 1010,235.0,17.32,0.0,11.70, Lid close,00000000,17.53,100.0,100.0,96.5,95.5
,18.41, Not Oper.,11011010,10 1010,235.0,17.96,0.0,11.70, Lid close,00000000,18.20,100.0,100.0,96.5,95.5
VCID: F399DCCFD2AD
1 Fault Found:
02023 - Terminal 87
