Hi,
Car's been running not to bad so not been on in a while. Its started to play up again and the latest thing is the drivers door lock.
The battery went flat (my fault) and when trying to lock the door when I took it out to charge, it would'nt lock with the key.
I've had a look and the cable that turns when the lock barrel is used is not connected at the bottom.
Question is, how the blazes do you get at the door lock from inside? It seems to be behind a solid metal section?
