VCDS Losing connection
dt-tdi
Active Member
Crewe
Hi all
I'm having an issue getting my VCDS to do a full scan, half way through my laptop pings up with the following screen shot warning.
I've tried re starting the laptop, disconnecting the lead from the car and it still happens, any ideas?
David
Vcds
same thing happened me and it was always at module 46. Contact ross tech and Jef will give you instructions on how to send debug file to find the problem. My one just disappeared after an update from ross tech.
Emailed Ross Tech today and got a helpful reply from Uwe, just awaiting a further reply from the info I have sent him.
Attached is a larger image of my problem which should now be visible.
Vcds1
Change this setting, see if it helps.
Hi Nigel
I've changed the settings as you have advised and it seems to have done the trick.
Did a full scan with the following results.
I am getting access to all of the modules that my cable is allowed to?
Sunday,09,March,2014,09:33:32:43365
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WAUZZZ8EX7A144772 License Plate: DT7734
Mileage: 65820km-40898mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8EX7A144772 Mileage: 65820km/40898miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 8E0 910 401 N HW: 8E0 907 401 AL
Component: 3.0L V6TDI G000AG 0050
Revision: --H03--- Serial number: XXXXXXXXXXXXXX
Coding: 0011171
Shop #: WSC 66565 257 00032
VCID: 2A5D6E2985564C4EE53-807F
1 Fault Found:
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 001 - Open Circuit
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 65747 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.17 V
Duty Cycle: 15.0 %
Temperature: 24.3°C
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E1 910 156 H HW: 09L 927 156 B
Component: AG6 09L 3,0 TDI 171 0070
Revision: --H01--- Serial number: 4256683
Coding: 0000002
Shop #: WSC 06325 000 00000
VCID: 2C5168318FA2527E17F-8079
No fault code found.
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH
Component: ESP8 quattro H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004426
VCID: 2E556239B9BE206E39B-807B
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 3233
Coding: 00000
Shop #: WSC 00000
VCID: 6DD7A53527389B76401-5196
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 00001
Shop #: WSC 06325
VCID: 3D77557537D8CBF6B01-4B32
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H12 3730
Revision: 91H12373 Serial number: 0036M0G4MUU4
Coding: 0031612
VCID: 3B735B6D7ACCC5C68E5-806E
Subsystem 1 - Serial number: 6332DRB404360C9EV
Subsystem 2 - Serial number: 6342DRB4042AD42BU
Subsystem 3 - Serial number: 6352ARB401D63E67W
Subsystem 4 - Serial number: 6362ARB401D6387AV
Subsystem 5 - Serial number: 63729RB401D9773CZ
Subsystem 6 - Serial number: 63829RB401D9770AV
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 02041
Shop #: WSC 06325
VCID: 418F29854B20AF16D49-4B18
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 983 A HW: 8E0 920 983 A
Component: KOMBI+WFS 4 H14 0200
Revision: 0200 Serial number: 00000000000000
Coding: 0007418
Shop #: WSC 01189 210 175629
VCID: 2D576535B7B85B76001-515A
1 Fault Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0007418
VCID: 2D576535B7B85B76001-5178
1 Fault Found:
01304 - Radio
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
Shop #: WSC 00000
VCID: EBD32B2D992C1546DE5-515A
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CH
Component: Komfortgerát T3B 4135
Coding: 06895
Shop #: WSC 06325
VCID: 79FF8165637037D6DC9-4B18
Subsystem 1 - Part No: 8E2959802F
Component: Tõrsteuer.FS BRM 0606
Subsystem 2 - Part No: 8E2959801F
Component: Tõrsteuer.BF BRM 0606
Subsystem 3 - Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
1 Fault Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 E HW: 8E0 919 283 E
Component: Parkhilfe 8-Kan H06 0010
Revision: 00H06000 Serial number: 00067802130629
Coding: 0001104
VCID: 326D7649AE86048E5D3-515A
End
Seems to read ok, except for radio of which I've advised via PM how to address possibly, keep all replies on here from now on please.
Tried to do another auto scan today and I'm stilling having the same problem as above with losing connection at module 46.
Have also tried accessing module 46 directly and the message 'No response from controller' flags up?
I tried my partners laptop just to be sure it wasn't an issue with my laptop and the result was the same.
Beginning to think there may be a fault with the module on my car?
Anyone got any ideas?
994
