Lambda sensors
Audi_A31.8T
south wales
Getting a few faults code for lambda sensors so though if just replace them
are they both the same or does any1 have part numbers I have a 2000 a3 1.8t aum engine code
also where is the connections located
thanks
soak them in vinegar see how you get on, it worked for me
What are the codes? don't assume a fault code for a sensor means it is faulty...
Address 01: Engine Labels: 06A-906-032-AUM.lbl
Part No: 06A 906 032 DK
Component: 1.8L R4/5VT 0001
Coding: 11500
Shop #: WSC 00647
VCID: 6ADB242A16DFE44E2A7-517A
WAUZZZ8LZ1A025983 AUZ7Z0Y1572803
4 Faults Found:
17524 - Oxygen (Lambda) Sensor Heating; B1 S1
P1116 - 35-00 - Open Circuit
17608 - Boost Pressure Control Valve (N249)
P1200 - 35-00 - Mechanical Malfunction
17511 - Oxygen (Lambda) Sensor Heating; B1 S1
P1103 - 35-00 - Performance too Low
17522 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 35-10 - Internal Resistance too High - Intermittent
Readiness: 0010 1101
Yeah... fair point... these suggest both are not happy...
This typically happens when you have done an N249 bypass or if not you have a faulty DV
Don't quote me but I'm pretty sure the post and pre work on different perameters, so are both different, I'm sure though someone can clarify!??
I'll take them both out and I'm sure I can take them to motor factors and get what I need cheers
17
513
945
