turbo chattering/fluttering
Readiee1.8t
hi guys not long ago fitted a new turbo to my S3 along with a relentless manifold, now I noticed that the dv was leaking so I change it over to my not long ago serviced 007p (along with new style piston) but the car still flutters/chatters? my vacuum pipe is also new going from bottom of inlet to top of dumpvalve. I will also mention that the car has had a N249 bypass but the module is still plugged in.
any ideas?
Lee
the vacuum pipe from inlet to dv is 3mm iirc
only crap pipe from what I can see is the one which goes to the oil breather thing on the tip?
car is running a standard map so ive got the green spring in
so if its chatter you are hearing, and there's a decent vacuum signal there then the DVs sticking or the pipes too small a sbore so its not acting fast enough.
Is it a flutter sound on lift off or venting woosh noise?
Sbore? What you mean mate and its definitely not a venting woosh noise, it is flutter under light accleration and hard accleration mate
right ive just had the 007p off with the engine running and the vacuum from the inlet is pulling the piston up in the valve so its not sticking, ive just changed the pipe from the inlet to the FPR too as it looked abit ropy but its still doing it :( I really don't want it to f*ck this new turbo :(
this Dv come off my golf turbo yesterday and was working perfectly fine on that so I know it cant be the DV.
im not prepared to go out and spend money on a oem dumpvalve when I know the forge 007p one ive got is perfectly fine I don't see the point?
if its not opening quick enough from insufficient vacuum vs too stiff a spring..... you dont have much choice
Right tried a new oem dv and its still the same! If the actuator on the turbo has been setup up incorrectly could this cause the flutter?
if oe dv still makes the fluttergate type noise, then it can only be infuccient vacuum to the dv surely?
long pipe small bore? n249 still there or direct off manifold ?
a sound clip might confirm what you describe as flutter from what we might call "normal" woosh...
