What have you done today?
3F1ED8ED 29BB 4988 9B82 59B22B66A88B
yeah, i saw that post too :p
always loved the burble of a 5 cylinder, and its about as close as i can find to that.
I’m tempted to go with this one
Reactions: Asim1
I’m still on the fence can get a 2nd hand 3” cat back for 300 sounds good in the video I seen but not sure if it was with valve open or closed
i was sorta thinking the same; sounds nice, but doesn't have that kick in the vids i have found. still a option tho if zinram are gonna be crap on customer relations side of stuff.
Been looking all day not sure if the valve is just a gimmick that would never get used could of got a 2nd hand custom for 300 today but missed out on it cause I couldn’t make my mind up
i was sorta thinking the same; sounds nice, but doesn't have that kick in the vids i have found. still a option tho if zinram are gonna be **** on customer relations side of stuff.
Tossing up between this and the Zinram exhaust as they're about the same price, just question how good those electronic valves are and how long they'd survive... Would prefer a vacuum actuated valve. Didn't realise Zinram were so hit or miss with the customer service side of things!
Rk o e does look well made, the Zinram valved exhaust is twice the price and the valve is after the back box I thought the point was to by pass the box? like you say vacuum would be best instead of having to use the remote
refitted the timing belt [ retarded timing, 1 tooth off] water pump, tentioner [ what a little git to recompress with no vice!!] all dust covers, engine mounts, wheel liner and other plastic bits underneath, crank pulley, aux belt and tentioner, evap-charcoal canister, rad header tank, power steering fluid res, charge pipe, brake booster hose and most the little bits that need doing.
just got a coolant flange on order, a set of plugs to grab, oil and a filter and antifreeze and i *hope* to be running for next weekend.
nice to see the car sat back on the floor after weeks off it :)
Reactions: Asim1 and S3AMJ
Sounds like it’s almost ready to start up, good work dude
Reactions: danny_dj3
Fitted a new MAF and also going back and forth with my 2 n75s. With one, the car pulls good low end and the turbo kicks in smoothly with the other the car feel less powerful low end but the turbo kicks in more aggressively. How should it be the second one is the ''new'' C version.
Reactions: Asim1
wont lie, im sh1tting it for the startup, i asked a mate who's well off to do it so if it goes tits up, its his fault and can pay LOL.
naw, but honestly, i'm certain i hit all the right torque specs, and off all the countless pages of advice here i think its gonna be a runner.
if not, then the spare block/top will get the works done to em and i will be taking the front off the car to get the engine out; dont wanna have to do that crap in a tight space again, i have literally no skin left on my fingertips ha! the joys of being a bigger framed chap eh!
Reactions: Asim1
Today other than working, grinding TD2 and ordering a 1440p IPS monitor, I watched this....
....so moist!... :D
Reactions: S3AMJ, MPH and Tj 0785
Today I have mostly farming... in the Division 2... :)
The Merciless Exotic Rifle...
...and the Sweet Dreams Exoctic shotgun...
...if of course you are into that sorta thing... which I am currently... until I can get started on fitting the turbo to my car of course :/
Reactions: S3AMJ and Tj 0785
well, as im on running in duties, i thought i would nip to the bro in laws to help him put up a fence.
Fat
looking clean again.
Reactions: MPH, hydro s3, Asim1 and 1 other person
So today i decided to give some attention to my recently acquired Agu
That is the air filter or should i say air filters that came out of the airbox, these things are so cheap yet the previous owner decided to glue 2 totally different air filters together, I mean WTF
WTF
and the cabin filter has also never been replaced, thats the original 20 year old audi filter that was in there.
Cabin filter
i must still do the mechanical stuff like the spark plugs, oil change, oil and fuel filter but im already afraid of what im going to find. i have a sneaky suspicion that the cambelt is probably also the original audi part on there from the year 2000
Reactions: Asim1
That is completely crazy glued filters together cabin filter does look original though best get that cambelt done ASAP. The air filter will not be working correctly as it's not sealed at the edges so possibly more cleaning to do in the intake manifold area
Sent from my SM-G930F using Tapatalk
Reactions: Asim1
I think you’ve won car with most neglect of the year mate. Truly shocking, can’t say I’ve ever seen that before. Makes you wonder what other gremlins you’ll end up finding! The car can only get better with your ownership that’s for sure
Reactions: Dohcwp
Hubs, bearings, pads, discs, ball joints and new abs sensors all fitted and done car drives amazing for the 2 mile test run afterwards. Just need to get tracking done all round now and I'll be happy. With regards to abs sensors in my thread the one that broke was from gsf and was really hard to try and put in. Ended up getting an eicher one from euros and it fit in straight away no fading about. Just incase anyone needs to change abs sensors
Reactions: danny_dj3 and MPH
Well done my friend keep up the good work
Reactions: Asim1
Did the Hubs come With Bearings?
Sourced an engine cover for the AGU, i dont like naked engines. not in a pristine condition but it was the best value for money one i could source.
WhatsApp Image 2020 06 26 at 112141 AM
Nice one I gave one of mine a tart up the other day came out o.k plastic primer satin black and then some Audi plastic sealant came out o.k
Reactions: Dohcwp, Asim1 and S3AMJ
Looks good, now that I’m gonna be using the AGN rocker cover, I can’t have a plastic engine cover
Reactions: MPH
You don't even see it on mine what with the inlet and covers lol
Would be pointless me changing the rocker cover over if I was to just cover it all I’m gonna still out the coil pack holes a little this weekend and get it sent off to be powder coated on Monday. Fit it next weekend.
Reactions: MPH
It will look good as its a simplistic cover I would like to see it when its done @S3AMJ :hubbahubba:
I’ll be posting it all up on my build thread for sure. Going to get it sprayed to match the other parts in silver. Nice clean look. Was going to be changing everything to a bronze finish but still can’t decide on a colour code yet.
Reactions: MPH
personally i think the ALT engine cover looks much better than the AGN Cover that everyone is going for
Reactions: Asim1
Yeah but does that bolt to our heads? I’ve looked into this rocker cover before and I can’t see how it would with work with VVT. Or the depth to cover the cams, this is for a 2.0 na engine.
they vvt would be an issue but on APY engines it shouldnt be an ISSUE, afaik the ALT is just a stroked 1.8 like an ADR in the A4's, it's still a 4 cylinder 5 valve engine, and i doubt audi would have gone and specially created that just for the b6 A4's.
From what I’ve seen side to side the ALT head cams sit flush to the top, so the ALT rocker cover sits flat. Our 1.8 heads are different in that respect, our cams are pronounced so the ALT cover wouldn’t fit.
You could swap the heads entirely.... I guess. That said If that was something that could easily be done then everyone would be doing it or using the 2.0 block if they were interchangeable.
The ALT's have fsi so maybe thats why the cams are different, but the blocks are more or less the same bar a few minor changes
i found this online
where he says our cars he means the B6's
06A (out of a transverse 1.8T, aka Mk4 VWs & mk1 TT)
06B (out of our cars)
Differences:
06A block has a smaller thermostat bore. I had to sand the lip off of the B6 A4 thermostat housing.
06B block has a shorter oil pump tube- direct swap though.
06B has a different oil pan due to B6 subframe- direct swap again. (this one was obvious)
Collected my charge pipe and AGN rocker cover from the Powder Coaters. Really pleased with the results. 2 day turn around and only £70!
Will be fitting it all over the weekend
Reactions: Asim1, hydro s3 and MPH
33
10
4K
61
6K
21
