Latest update, I have purchased a Forge High Flow Discharge Pipe which should hopefully arrive this week
Here is the OEM pipe which is known to crack if you have tuned your S3
And here is the Forge item:
Designed as a direct replacement for the OEM plastic discharge pipe used on 1.8T and 2.0T engines found in various VW, Audi, Seat and Skoda models.
Full mandrel bent single piece hard pipe with larger bore size for increased flow. This ensures high amounts of air are discharged from the turbo charger and therefore releasing the full potential of your engines capability’s.
Unlike the OEM discharge pipe that is prone to failure from increased boost or many heat cycles the Forge Motorsport high flow discharge pipe will not crack or fail ever.
Are you going to replace the Turbo Outlet pipe also ?
