ABS/ESP and Braking system fault
KENCUTH
Hampshire
Hello, This is my second post and not the best but here it goes.
I changed my alloys over from 17s - 18s about 2 months ago and have had no issues until 2 weeks ago when my ESP ABS and braking system fault signal come on when i turned the car over. This came on when i was parked up, then i pulled away to hear three dings, which would be part of the fault.
When driving down the road all these signals dissapeared (to my delight). I then parked up again, to then return turn over the engine for the warning lights t appear again. I drove for roughly 1 mile for them to disappear again. After a few days of this occurring, the warning lights have now stayed on permanently. I have tried all different threads to find out the causes to this issue. Could it have been my wheels??
Where the warning lights kept on coming on and going i could only imagine that it was a sensor, but when searching the forums there was nothing concrete about this other then the fuse box on top of the battery which is all intact.
I hooked up the motor to VCDS lite to hopefully shed some light, with the below results.
VCDS-Lite Version: Release 1.2
Wednesday, 09 October 2013, 18:23:11:0
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,16,17,22,35,37,45,55,56,57,75,76
Address 01: Engine Labels: Redir Fail!
Controller: 8L0 906 018 N
Component: 1.8L R4/5VT 0002
Coding: 05710
Shop #: WSC 06435
VCID: 3A07B1EB3547
1 Fault Found:
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 08: Auto HVAC Labels: Redir Fail!
Controller: 8L0 820 043 M
Component: A3 KLIMAVOLL
VCID: 321799CBED37
Note: Excessive Comm Errors
Address 15: Airbags Labels: 8L0-959-655-AI8.LBL
Controller: 8L0 959 655 J
Component: Airbag Front+Seite 3008
Coding: 01104
Shop #: WSC 06435
VCID: 45FDD2174CB9
No fault code found.
Address 17: Instruments Labels: 8L0-920-xxx-17.LBL
Controller: 8L0 920 980 B
Component: AB-KOMBIINSTR. VDO D11
Coding: 01444
Shop #: WSC 00000
VCID: 321799CBED37
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0Y1488686
Address 22: AWD Labels: 02D-900-554.LBL
Controller: 02D 900 554 B
Component: HALDEX LSC ECC 0006
VCID: 1F31607F8EA5
1 Fault Found:
01316 - ABS Control Module
49-00 - No Communications
Address 35: Centr. Locks Labels: 8D0-862-257.LBL
Controller: 8L0 862 257 P
Component: CV-Pump, Alarm, RC D13
Coding: 15178
Shop #: WSC 06435
VCID: 42F7C90B5D97
7 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00991 - Interior Lights
28-00 - Short to Plus
00956 - Key 2
09-00 - Adaptation Limit Surpassed
01134 - Alarm Horn (H12)
Address 45: Inter. Monitor Labels: 4B0-951-173.LBL
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
VCID: E0B3A383735B
Address 55: Xenon Range Labels: 4B0-907-357-AUT.LBL
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00002
Shop #: WSC 06435
VCID: E5BDB2976C79
End --------------------------------------------------------------------------------------------------
Any ideas would be appreciated, as im hoping this isn't a new ABS pump or Haldex.
I had something similar to this and it turned out to be a wire that had frayed through in the bundle running to the abs wiring plug, I suggest you get a multimeter and wiring diagrams and go from there. Do you have full version vcds? if you go into the engine module and measuring blocks, go to block 125 this will tell you if the ecu can communicate with the abs module.
it might well be but for the effort of checking continuity in the wiring, will save spending money on a part that's not needed I found this out to my cost twice lol
Hello thanks for the replys, i will check the abs wiring plug and get the multimeter out tomoz.
I do have VCDS lite full version and did as you said and ran measuring blocks 125 in the engine module.
Don't know whether it talked to it, but in the second box along i had ABS 1 show up??
NtCgAAoFBE1KuxmIvUKeuZoMiIZoXMtykAAIBCEVYgP7s4rdTJ62HlDVIHAABAO6nWwylCtPj1ec5KeTzlsrG4gRmYAAAAQEbIuAcAAACAVsi4BwAAAIBWyLgHAAAAgFbIuAcAAACAVsi4BwAAAIBWyLgHAAAAgFbIuAcAAACAVsi4BwAAAIBWyLgHAAAAgFbIuAcAAACAVsi4BwAAAIBWyLgHAAAAgFbIuAcAAACAVsi4BwAAAIBWyLgHAAAAgFbIuAcAAACAVsi4BwAAAIBWyLgHAAAAgFbIuAcAAACAVsi4BwAAAIBWyLgHAAAAgFb+H+y1xp2hl28mAAAAAElFTkSuQmCC
if I remember right that means that the ecu can see the abs controller just cant talk to it if you know what I mean...I piggybacked a long length of wire from the diagnosis wire also called the k-line its the grey/white wire in the diagnostic port connector to the same grey/white wire in the abs connector block, the fact that your abs module doesn't even show up on your auto scan would lead me to think its this wire that might be the issue.
is it an s3 you have? if so what year and ill see if my diagram is correct.
Right i see what you mean. So i need to find/follow the grey and white wire from the abs module see if all is intact. This is what i was hopeing for, as it takes the presence away from the abs pump/module being the culprit.
I have a S3 2000.
I have a S3 2000.
You will have trouble tracing it as it goes up into the back of the speedo clock and then to the abs sensor, so I would try either by-passing the clock and taking a wire right from the diagnostic port to the abs plug, its a pain in the **** I had to splice into it so make sure your happy you have the correct wires lol
Yes my engine is an APY. Sounds really difficult. Was thinking if the colour is known i could trace the wire the opposite way?
683
5K
