A3 3dr Parcel Shelf:
Dan_Mol
Had my parcel shelf out today as it just doesn't sit correctly. The previous owner has screwed his own hinge pin that sits on the plastic in the boot.
I can see from the trim and various screw heads this is not correct.
Anyone got a part number for the correct hinge pins, under side of parcel shelf, sits pretty much on the seat backs.
Anyone with ETKA would be much appreciated.
You got a pic of exactly which part you're referring too, as if its what I believe, its not a separate part & needs a whole shelf.
Taken from a photo of yours, as going to sort the 8L ropes too.
SDC10119
The bits right at the bottom of your parcel shelf, left and right corners.
Are those parts attached to the shelf, as mine are different to that, don't sit quite right and screwed on with self tappers.
Well those aren't available separately, I've bonded some back on that have come of.
Whilst were here are them bag carriers an option and the net? I have the rear mesh
screen that pops up.
Darn, I was hoping that were not the case. Looks like a new parcel shelf is in order or swap with some unsuspecting Audi garage ha.
Thanks for your help NHN.
