Map sensor fault
Jonesymk2
After changing my ecu I've always had a hesitation which I thought was coilpacks,I've changed them for red coil packs and the hesitation is still there,scanned the car with the computer we use at work and it came up with a few faults but there is 1 fault that won't go
would this point towards the map sensor being knackered
[h=2]16622/P0238/000568 - Manifold Pressure/Boost Sensor (G31): Signal too High[/h][h=4]Possible Symptoms[/h]
  • Malfunction Indicator Lamp (MIL) active
[h=4]Possible Causes[/h]
  • Wiring/Connector(s) from/to Manifold Pressure/Boost Sensor (G31) faulty
  • Manifold Pressure/Boost Sensor (G31) faulty
[h=4]Possible Solutions[/h]
  • Check Wiring/Connector(s) from/to Manifold Pressure/Boost Sensor (G31)
  • Check Manifold Pressure/Boost Sensor (G31)
How would I check the sensor to see if its working so I can possibly eliminate that or the wiring
653
MPH
499
551
928
