Help with Coding i have a few things show up malfunction in VCDS
Yonner
Oldham
Hi guys , girls ,
i run a full scan on my S3 tonight and it come up with a few malfunctions , it has somat to do with the Nav and radio and also says Tv tuner in there too? i do have 2 things on my window screen which i think are aerials, i hope some one can help me on this, any advice is appreciated :)
ok here are the errors in vcds i am copying and pasting info:
Address 37: Navigation Labels: None
Part No SW: 8P0 035 192 Q HW: 8P0 035 192 Q
Component: RNS-E HIGH EU H75 0650
Revision: 06S Serial number: AUZBZ7H0903812
Coding: 0209757
Shop #: WSC 00000 781 01234
2 Faults Found
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 129
Mileage: 84111 km
Time Indication: 0
Date: 2013.08.06
Time: 16:11:58
02005 - Coding Pin
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 129
Mileage: 84111 km
Time Indication: 0
Date: 2013.08.06
Time: 16:12:08
next one is:
Address 56: Radio Labels: None
Coding: 0209757
2 Faults Found
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 129
Mileage: 84111 km
Time Indication: 0
Date: 2013.08.06
Time: 16:11:58
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 129
Mileage: 84111 km
Time Indication: 0
Date: 2013.08.06
Time: 16:12:08
and last one:
Address 57: TV Tuner
Cannot be reached
thanks for any help!:rockwoot:
i will take a look at the link , thanks for your quick reply NHN :)
Go into the gateway (19 iirc) coding and select the rnse, deselect the tv tuner.... Also check the coding for the rnse.... Sounds like someone retrofitted the rnse but didn't code it properly. I see this a lot and I'm sure Nigel does too.
Ahh ok I will have a look in the gateway and see what's about , the nav is actually working in the car so I don't know why it's saying malfunction ?
Cheers ash
Yes it will work since its plugged into the can network but it doesn't look like its coded correctly... It's not a big issue but it would be good to code it all the right way
I will get my laptop out now , just found this under steering wheel while fitting footwell bulbs
just checked my spec with a pr decoder mate and it says my car come with nav , look here are all my PR codes
PRCode: 0GG = Emission standard EU4
PRCode: 0YC = Weight range 3 installation control only no requirement forecast
PRCode: 1AT = Electronic stabilization program (ESP)
PRCode: 1KW = Disc brakes rear
PRCode: 1N3 = Speed-related variable steering assist (Servotronic)
PRCode: 1SA = Without additional engine guard
PRCode: 1ZK = Disc brakes front
PRCode: 2PF = Leather trimmed multi-function sports steering wheel
PRCode: 3FE = Electric slide/tilt sunroof with sun screen/sunblind
PRCode: 3L3 = Manual height adjustment for front seats
PRCode: 3NU = Rear seat bench unsplit backrest split folding with center armrest
PRCode: 3Y6 = Sun screen for rear window
PRCode: 4GP = Windshield in heat-insulating glass withsunshield and viewing window for vehicleidentification number
PRCode: 4K2 = Radio remote controlled central locking SZV
PRCode: 4KC = Side and rear windows in heat-insulatingglass
PRCode: 4R4 = Power windows with comfort operation andcircuit breaker
PRCode: 4UE = Air bag for driver and front seat passenger
PRCode: 5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
PRCode: 5RU = Right exterior mirror: convex (large viewing field)
PRCode: 5SJ = Left exterior mirror: convex
PRCode: 5TG = Decorative aluminum inserts dulling
PRCode: 6C0 = Curtain air bag
PRCode: 6XK = Exterior mirrors: automatically dimming electrically foldable/adjustable/heated
PRCode: 7A2 = CD changer
PRCode: 7K6 = Flat tire indicator
PRCode: 7Q2 = Navigation system with color screen
PRCode: 7X1 = Park distance control
PRCode: 8BP = Bi-functional headlight with gas discharge lamp
PRCode: 8GU = Alternator 140 A
PRCode: 8Q5 = Headlight-range adjustment automatic/ dynamic with dynamic bending light (AFS 1)
PRCode: 8Z5 = Not hot country
PRCode: 9Q2 = Multi-function display/on-board computerwith check control
PRCode: CC1 = Alloy wheels 7.5J x 18
PRCode: D3Q = 4-cyl. gasoline engine 2.0 l/195 kW 16V turbo FSI homogeneous Base engine is TA2
PRCode: EA0 = Without subsequent warranty
PRCode: FA0 = Control of standard production
PRCode: G12 = Front shock absorption
PRCode: J0L = Battery 340 A (70 Ah)
PRCode: L26 = Suspension range 26 installation control only no requirement forecast
PRCode: QG1 = Service interval prolongation
PRCode: TA2 = 4-cylinder gasoline engine 2.0 L unit 06F.D
PRCode: U1B = Instrument insert with mph speedometer clock tachometer and trip odometer
PRCode: UB5 = Rear shock absorption for sports design
PRCode: UG0 = Without hill hold control / hill descentcontrol / comfort driving assist
PRCode: X2B = National sales program Great Britain
Any help on this why the tuner is not working ? I noticed the antenna on the inside of the car have red led lights on them but are not lit up ? The actual DVB alpine tuner does have power because the led is lit up on the unit ?
