Front drivers tyre looks flatter than the rest but all pressures the same?
Mikey3000
Hi guys,
I have noticed that my front drivers tyre appears slighty flatter than the rest.
Now, I run standard 16" alloys with radial tyres so I know it is normal for them to look as if they are flat but should there be a difference in appearance between the o/s front and n/s front tyre. I have triple checked each tyre pressure and they are both running 35psi.
Is this difference in appearance normal or indicative of a problem?
I have noticed that the engine is mounted more too the off side of the vehicle. Could it simply be a question of weight distribution or is that just wishful thinking?
Any help/advice/ideas would be very much appreciated :)
Cheers,
Mike
Yep, tyres are all the same size, same make, same model and same tread.
