- Joined
- Apr 9, 2006
- Messages
- 11,376
- Reaction score
- 926
- Points
- 113
Hey guys
Hope you are all well ??
Was driving the car on Saturday and was in 6th, went to put my foot down and it pulled away but then sort of hesitated almost like a flat spot, i let go and put my foot down again and it carried on as normal.
I did a scan today and this fault code came up, now ive done a search and can see there is a similar thread running at the mo, but wasnt sure if they were the same thing as the error message is slightly different.
This is what the Ross-Tech site says:
Possible Symptoms
Reduced power output
Limp mode
Possible Causes
Boost Pressure too High
Hoses/Pipes incorrect connected, disconnected, blocked or leaking
Charger Pressure Control defective
VNT (variable nozzle turbo): nozzles stuck
Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
Check Hoses/Pipes to/between Components
Check Solenoid Valve for Boost Pressure Control (N75)
Check / Clean / Replace Charge Pressure Control
Check / Clean mechanism for variable nozzles
I've been out to the car and done a quick visual check and all pipework etc seems to be ok, I have the N249 delete on the car as well and all piping to and from this seems to be intact too, so im presuming it could be the N75 thats causing the issue??
Is this right, if so, is it just a case of replacing it?
I have cleared the fault and will be taking it for a spin tomorrow, i'll do another scan in the evening and see if the fault comes back and more to the point if I get the issue tomorrow as well.
Any help much appreciated.
Nilz
Possible Symptoms
Limp mode
Possible Causes
Possible Solutions
Nilz
