Just been out poking about under the bonnet and I've found if I tilt my ICM a certain way my lumpy idle disappears. Could a loose connection / wire in the ICM be causing my lumpy idle issue?
Yeah it's been that way for a while, new plugs and cleaning throttle body tomorrow, will check for leaks under the inlet manifold too. Wasn't too bad on the old exhaust but it sounds like I'm sitting revving the engine boy racer styleee at junctions and lights with the new one. I suppose when it's your own car you become hyper-sensitive to these things. It's just really annoying just now
Well I changed spark plugs and cleaned the throttle body. Much better. Very slight fluctuating idle but so much better. Only seems to occur when my foot is on the brake now, not ideal but I can live with it
