MFSW Retrofit Problems
leeds2592
When I grow up, I want a 964!
Leeds
Hi all,
Fitted a MFSW to my A3 yesterday including a new highline ecu. Everything fitted ok and buttons work on the wheel after coding but I've got a few problems when I've tried to drive it. I'm getting an ESP fault and no power steering.
Ive done all what is stated on the Rosstech website for steering assist such as turning steering wheel full to left and then right and going for a quick drive but the problems are still there. I've tried to clear fault codes in 44 Steering Assist and I keep getting fault 02546 - Steering Limit Stop No or Incorrect Basic Setting / Adaptation.
Any help with this would be massively appreciated as its doing my head in!
Do the adaptions again following Ross Tech's guide, it will go. Had to do mine twice to get it to accept
Also sometimes it may need a little longer on each lock - try holding the wheel over for 30 seconds each way
Top man!! Just did it for around 30 secs instead of 5 and I've sorted that.
Next problem is the airbag light is now on which wasn't on before I fitted the MFSW. I've scanned it and below is that fault codes.
Sunday,17,February,2013,17:13:45:40297
VCDS Version: Release 11.11.5
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Control Module Part Number: 8P0 959 655 H HW: 8P0 959 655 H
Component and/or Version: Airbag 9.41 H12 3720
Software Coding: 0071612
Work Shop Code: WSC 06314 000 00000
VCID: 479B670036309D20A06
2 Faults Found:
00588 - Airbag Igniter; Driver Side (N95)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 1
Fault Frequency: 1
Mileage: 115170 km
Time Indication: 0
Date: 2013.02.16
Time: 00:05:48
01587 - Igniter 2 for Airbag; Drivers Side (N250)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 115170 km
Time Indication: 0
Date: 2013.02.16
Time: 00:05:48
Actually, scrap that. Just cleared codes for airbag and gone for a drive and light has gone.
Glad you got it sorted, can't wait to code mine in tomorrow!
A week whith no power steering or ESP has been 'different' shall we say. Haha
How'd you drive for a week without it?!? I was struggling just turning out of my drive without any power steering haha.
I've got another problem (Hopefully the last one).
The plastic cowling at the top of the wheel is not clicking back into place at the back. This is causing the plastic to be pushed forward and rub when the steering wheel is turned and the gap seen below. The front of the plastic has clicked in and is fine though. I've tried pushing it back down an all sorts but no joy. Anybody help?
Trust me its so annoying, just about ended up in my neighbours fench the first time I went out!! Haha
Glad my VCDS Cable came today just about to go and sort it.
906
NHN
NHN
