Help heating issues
Biddy
Hi all right its had a full flush new rad all bleed but still bottom hose is cold when im driving im getting some heat but stand still and it goes cold help
It sits at 90 and no it hasnt had stat
your bottom hose will be cold! its the colder air back in to the engine from the rad and in this weather there will be very little flow in the rad
sounds like you need to check the motors for the heating inside the car or the heater matrix could be sludged up
Would it not be a littleh warm instead of stone cold
If the car sits at 90 then the stat is fine!
if it only gets to about 70 the stat is on its way
if it doesnt move off the bottom mark then stat is stuck open
if you want to change it for peace of mind go ahead
Ok mate if stat is ok i wont change as they are anything from 50 to 100 notes i have noticed that the fans run constant with engine started we took the sensorj plug off but they still run could the air con system cause them to be running and would that cause the prob with the heating
what engine is it?
you need to get it scanned for faults for the fans its probably a duff sensor
If the temp sensor goes tits up it will put the fans on constantly
get the fan issue sorted first then go from there
886
893
