fault code help
tdi-man
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 H HW: 8P0 920 980 H
Component: KOMBIINSTR. VDO H25 0140
Revision: D09 Serial number: 2242DD09005264
Coding: 0004403
Shop #: WSC 06795 116 50998
VCID: 3C7330C306FB
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 00000011
Fault Priority: 1
Fault Frequency: 1
Mileage: 186377 km
Time Indication: 0
Date: 2010.11.26
Time: 00:20:47
GOT THIS FAULT ANY BODY KNOW WHAT IT IS PLEASE ?
THANKS
00003 - Ross-Tech Wiki
[h=3]00003 - Control Module: Defective[/h][h=4]Possible Causes[/h]
  • Control Module faulty
  • Control Module Software Issue
[h=4]Possible Solutions[/h]
  • Check Control Module
    • Check for Control Module Software Update
  • Replace Control Module
When found in Audi A3/S3 (8P): Instrument Cluster:
  • Check/Perform Instrument Cluster Service Interval Settings (Adaptation Channels 42, 43, 44, 45 and 49)
got the following readings ?????????????
Hi guys,
Sorry to revive this but I am getting the exact same code above. I have checked the readings and there was a discrepancy which has been corrected and the readings are now identical to above. Fault codes were cleared but they return straight away.
The issue I see is that the DIS works for a couple of days then goes off so cant see Fuel range, MPG, etc. To fix this temporarily, I have to remove the battery terminal and replug it to reset it. It then starts working again and then goes off. The above fault code is seen even when the DIS is OK.
Fault Code below:
Component: KOMBIINSTR. VDO H25 0080
Revision: D06 Serial number: 2247CD06000594
Coding: 0004403
Shop #: WSC 00116 067 57207
VCID: 3C7D03687F2210FE875-8069
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 68437 km
Time Indication: 0
Date: 2011.10.28
Time: 09:55:25
Also, in the instruments coding, does anyone know what the Coding XXXXXX3 refers to in 0004403? VCDS just says "illumination" and nothing else.
Any advise?
Thanks,
Dips
549
465
