Removing badges
RA3SRS
I have "A3" and "1.6" badges on the back of my car. Are they glued on or will there be holes if I remove them? Hopefully they are just glued on.
Glued. Dental floss and a bit of tcut will do it for you.
Reactions: snowball1969
Rather than t-cut as that can remove your paint you could try something like auto glym tar remover, as I just recent removed mine from my A3 this worked a treat.
Good idea with the dental floss as I poured loads of the tar remover over badge to soften adhesive
Paul.
simple as this!
heat with hair drier,
saw off with dental floss or fishing line,
remove the sticky residue with WD40 on a rag,
get rid of shadow left behind with T cut!
sorted!
PVC cleaner works well, and it's cheap.
i used a product from halfords, hot water and take down badges and halfords spary product and wait few minutes.
called Sticky Stuff Remover gel
Reactions: renton
15
524
