washer motor
snates
I have a 2000 tt fwd and my low washer indicator is flashing but its full, to make thinks worse I cannot hear the pump working when I try to activate it. Is there a common problem or easy solution and where shall I look? Thanks guys
check the wiring plug on the motor. try taking the plug off then connect a test lamp across the plug, get a mate to activate the switch, if the light comes on, then you are getting power to the motor and the problem is with the motor. If no light, then the problem is in the circuit, possibly a fuse or damaged switch?
I
682
