1.8TFSI and 2.0TFSI S3 : Metallic Rustle/Rattle between 1500-3000 rpm
Dakar Apr 1, 2014
  1. Dakar
    Dakar Member
    37
    There have been numerous posts in various forums and threads from people experiencing this problem. Let's try and collate all the information we have so far.
    Vehicles affected: A3 1.8TFSI and 2.0TFSI S3 engines on the 8V chassis. (and potentially Seat Leon 1.8)
    Sound: Rustle/Rattle sound heard at low rpms, between 1500-3000. The noise has been reported to be more prevalent during colder temperatures.
    Example: https://www.youtube.com/watch?v=vK7uVtBok48 (you'll hear the sound around the 9second mark)
    The 1.2, and 1.4 A3 and Golf 7 engines have had similar 'rattle' problems which this issue sometimes gets confused with, but that could be rectified with an attached clip part. Unfortunately the above problem cannot be fixed with the clip because the turbo's are completely different on these engines.
    There is a long German thread detailing the problem too, Google Translate should give you the basic information:
    1.8TFSI und 2.0TFSI S3 - Sammelthread: Rasseln im Bereich Beifahrer von der Abgasanlage : Audi A3 8V, 8VA & 8VS
    Please post if you're experiencing this problem too.
    Engine:
    Current vehicle age:
    Details on how you hear the noise:
    Any information/testing/work you have received from your dealers/Audi:
  2. Dakar
    Dakar Member
    37
    Engine:
    1.8 TFSI Stronic
    8 months
    Since I purchased the car, I can hear it every time I drive. Sometimes quieter sometimes very loud and audible over the radio and outside the car.
    I've had numerous tests done, from exhaust to wastegate to turbo. Sound recording equipment installed by Audi and the noise measured. Turbo was replaced last week in an effort to resolve the problem, but made no difference. Audi HQ told me several cars were experiencing it and hoped replacing my turbo would be the solution, which they could roll-out to the others..
    Currently they're back to the drawing board trying to figure it out, the engineers at Audi HQ are apparently investigating but no news or updates. I don't think enough people are reporting this to Audi to give it priority.
  3. andywil13
    andywil13 Active Member It's my birthday
    380
    68
    I have the 1.8 TFSI (auto) and have this problem. Currently waiting to hear back from my dealer.
    I would describe it as a metallic sound. You can hear it slightly when in the car, but if someone else drives the car off my driveway it sounds worse. Now its summer in the UK, I can hear it more with the window open.
  4. danilotto
    danilotto Active Member Audi S3
    187
    47
    Same problem here.
    2.0TFSI S3
    1200 km
  5. scrich7
    scrich7 New Member
    This is interesting. Joined today as always liked the new A3, albeit I have a new Leon 1.8 which I'm fairly certain has an identical engine.
    I'm guessing the sound in experiencing is the same, tends to be around 2k rpm and is more prominent when the engine is cold. I'd probably describe as a kind of rustling leaves type noise?
  6. JohnM100
    JohnM100 #teamSepang VCDS Map User Gold Supporter
    952
    394
    Yep I have this too.
    1.8T S-Tronic ~5000 miles.
    It's a hollow metallic tinkling rattle noise somewhere between the sound of a twig in a bicycle spoke and a small stone in a (metallic) hubcap. Reminded me of the noise a jet engine makes when boarding a plane and the turbine fans are free spinning very slowly.
    Most noticeable when cold and especially 1750-3000 rpm on gentle acceleration.
    Audi are looking into it.
    Dakar - there are quite a few threads on this already and I know your intent is to consolidate. Suggest also change the title as its not a scraping noise (at least not in my case or in the video).
    John.
  7. Dakar
    Dakar Member
    37
    Yup, good description
  8. Dakar
    Dakar Member
    37
    Sure, but what does the noise sound like then. It's not a 'rattle' in my opinion either. Everyone describes it a little differently :think:
  9. danilotto
    187
    47
    Yes! This is a perfect description of the noise.
    Someone noticed if it tends to get worse? Are we sure it does not affect or degrade other components?
  10. JohnM100
    952
    394
    Mine has got louder over time yes.
    As for effect on components? I guess no-one will know until the root cause is identified.
    danilotto likes this.
  11. danilotto
    187
    47
    Someone noticed if the noise occurrence affects, at a certain point, the performance of the car? (i.e. loss of thrust)
  12. Dakar
    Dakar Member
    37
    I think you definitely notice the noise more, whether it gets worse over time is hard to say.
    Audi have assured me several times, and in writing, that this problem is not causing any damage. But I take that sceptically seeing as they can't even deduce what's causing it..
    I haven't felt any loss in performance.
  13. danilotto
    187
    47
    Obviously Audi cannot admit that it causes a damage. Event if it could be. There would be a crowd of panicked owners in front of their dealers.
    As an electronic designer I cannot understand how they can say they are unable to locate the root cause of a product they built from scratch and know in the whole assembly process. I know my products and I always can troubleshoot them, also if the fault is from a supplied component due to the fact that the interaction with other parts must be fully understood before releasing the product to the market. It is even more true if you think that plenty of super-brain german engineers are supposed to design the car.
    In the end
    1) If it does not cause damage to other parts of the car, compromising its reliability during time
    2) If it does not alter the performance of the car
    3) If it does not get worse
    then I think I can live together with it. With such complex mechanical devices (ok not a jet engine nor a space shuttle rocketdyne engine) it is very hard to obtain stable behavior in the lifespan of the products.
    My bmw had a squeaky rear suspension at 8000 km and no-one in BMW has been able to fix it.
  14. S3 TRS
    S3 TRS Active Member
    497
    226
    43
    yup summer is definitely here . foggy and cold. good old British summer! :icon_thumright:
  15. andywil13
    380
    68
    My Audi dealer just called me. When i took this into them the other week, they said the noise was a "characteristic of the car" They have now said that Audi are aware of the issue, but no fix as of yet.
    At least they are admitting to it now. Apparently Audi centers are being told not to replace any parts for this problem at the moment, so sounds like they are trying to get a proper fix. They will show me the bulletin when I take the car in next week for a firmware update to fix something else (sigh)
    will see if I can get a photo of the bulletin and post it up
  16. Dakar
    Dakar Member
    37
    Nice, good to hear Audi is being more transparent about the problem.
  17. Dakar
    Dakar Member
    37
    Ever get that bulletin?
    Here's the german one google translated:
  18. danilotto
    187
    47
    So they now discovered the root cause of the noise: the wastegate rod! Right?
    It also looks like that it does not cause damage to other components of the engine or exhaust system.
    The solution looks staightforward to my eyes: something like a weight to change the resonating frequency of the rod.
  19. Joetidman
    Joetidman Well-Known Member
    1,104
    582
    I imagine they'd need to change the component for something with the same dimensions etc, but with a different material makeup to adjust the resonating frequency. However, given the risk of doing that with an untested component (not to mention cost), I doubt they will go down that route...
    Might be a ECU adjustment to adjust turbo parameters to avoid it, but they would have knock-on effects as well, I suspect hence they don't have an answer right now...
  20. veeeight
    veeeight I am a very pretty girl VCDS Map User Black Edition
    6,849
    4,764
    Hmm.
    It's an electrically operated wastegate on this particular engine.
  21. labmousee
    labmousee New Member
    I have the same problem from the moment I took my Leon MK3 1.8 DSG from the dealership, about 6 months ago.
    I am not around ~5000 KM and I am almost sure it sounds worse.
    I would describe the noise as a metal broom being dragged on the asphalt. 1500-2500 RPM.
    I wanted to locate a recorder under the car to record the sound, but didn't have the chance yet. Does anyone have a decent recording of the noise?
  22. Dakar
    Dakar Member
    37
    Heh another good description. Haven't been able to get a good recording or find one from someone else.
    Please give try see if you can, I'm also thinking of attaching my gopro under the car - might work.
  23. T-800
    T-800 Well-Known Member Team Glacier TFSI Owners Group VCDS Map User Audi RS3 s tronic
    1,952
    1,621
    I had something similar on a MK6 Golf GTi a couple of years back, sort of rasping rattle between 1600-2500 revs, well known issue (same engine family E888 i believe)
    It went into VW Oldham and they were aware of the issue, apparently the fix for those cars was a 'Clip' put on the wastegate rod to stop the vibration at certain revs.
  24. andywil13
    380
    68
    I wonder if a few of us ranting on the Audi twitter page will work? (assuming they have one) I've heard companies are quick to respond to public complaints
  25. labmousee
    I think what you had was this noise which was caused by the mesh on the downpipe, no?
    https://www.youtube.com/watch?v=__aLctQuLdk
  26. T-800
    1,952
    1,621
    it was to do with the wastegate actuator rod and as i said above the fix was to put a special clip on it, spoke to one of the technicians at VW when i collected the car, there is a video on you tube that shows someone putting the clip on.
    https://www.youtube.com/watch?v=xAkkIEMm3UQ
  27. danilotto
    187
    47
    I cannot understand: Audi just told that there is no fix at the moment. So how the video is related to our problem?
  28. JohnM100
    952
    394
    Great description!
    John.
  29. Dakar
    Dakar Member
    37
    It doesn't - thats a seperate issue for the Golfs that a clip can fix. That clip does not work on the 1.8 and S3's because their engines are designed completely differently - a new solution needs to be designed by Audi.
    They are officially working on it now from the bulletin they sent out, we just have to be patient..
  30. T-800
    1,952
    1,621
    It's not i was just showing Labmousee that it wasn't the mesh on the downpipe.
  31. labmousee
    The sound that I have sometimes resembles to the sound that the mesh makes.
  32. STERLING VOID
    STERLING VOID Active Member
    145
    What does that mean?
  33. JohnM100
    952
    394
    I think it means no repair attempt at this time, until a solution is found.
    John.
  34. STERLING VOID
    145
    So what if my car is out of the one year warranty, would they still apply the fix?
  35. Dakar
    Dakar Member
    37
    Yes they definitely will, they just mean claiming warranty to get your turbo replaced is not allowed as this won't fix the problem anyway.
    STERLING VOID likes this.
  36. Joetidman
    1,104
    582
    I can hear a highpitched metallic 'tinkling' sound under gentle acceleration at low-ish revs, is that what you are all referring too?
  37. labmousee
    Ya ya
  38. Silky-S3
    Silky-S3 Is loving his new 8V S3!
    1,407
    343
    I've got this issue too.
  39. Scott
    Scott Well-Known Member
    1,306
    126
    I had the wastegate rattle on my previous MK6 GTI but as mentioned, it's a different fix. I haven't noticed it on the S3 but I have noticed it seems to make a 'very slight rattling' noise even at idle-3000rpm, I dunno if it's this or not but I'll just wait for a fix and ask them to do it anyway
  40. dragon
    dragon Active Member
    209
    89
    That's what I hear Joe!!
    Joetidman likes this.
