- Joined
- May 17, 2017
- Messages
- 106
- Reaction score
- 16
- Points
- 18
If you got to factory settings and the code you need is 126 then you can change settings for dimming etc and also for default volume settings etc.
To turn the screen off you hold that little box with a X in it for a second or two and the screen will go off.
What is your fm signal like? I’ve got a octo core android 6 unit but there’s something wrong with it so I’m sending it back and getting a refund. Mine doesn’t have the fakra connector for radio mine has a din adaptor with a separate power cable that has to be connected so I just wondered how it worked without the power cable and only using the fakra connection?
Yes m8 had a look in factory settings but nothing to do with dimming jumped out at me so i left well alone until i get a bit more time to look in to it .
Nice one with the screen button didn't think to hold it for a few seconds i will give it a try in the morning. cheers
No need for a power cable m8 i just plugged in the fakra cable and it picks up fm and am no problem .
There is a power antenna cable in the loom but its not needed for mine .
I drove around in an old jag for a time many moons ago. it had a motorised aerial . when you started the car it rose up out of the rear wing
Maybe its for that !
cheers eddom1971
