Funny story, a guy in work owned it before, sold it to someone unknown to us in the middle of nowhere in Wales, who then advertised it a few months later, my boss was looking for a cheap hack to use while he was renovating his house, and found this. He turned up at the guys house, and couldn't believe it was the car once owned by the other guy in work.
Anyway he used it for a few months until the mot ran out and half jokingly said did I want it for £90. I thought bargain. But alas I already had a few cars and not too much space so I didn't say yes. Anyway a few days went past and the price dropped to £60 and he literally said either I had it or he was going to weigh it in. What I really wanted was a MK4 Golf GT TDI but funds not allowing I thought if nothing else I could get some experience of the vw 1.9 TDI engine for when funds do allow. So I thought well why not.
Well onto the car. It was a state to say the least. But after a few hours of hard work it looked a lot better.
It's a 1.9 TDI (red i) I think this means it's a 110bhp model, and has been fitted with a little tuning box from TDI tuning. Not normally a fan of cheap tuning boxes, but to be fair it goes like stink (noticeably quicker than my old 306 dturbo) It's done 190k and the paint work isn't the best in a few areas, and it's red. But hey ho, worse things happen!
Having looked over it over, all the tyres were tired. I could get cheap tyres but paying £12.50 a wheel to swap the tyres over, suddenly they weren't so cheap. Thinking all 5 stud VW/ Audi's were interchange I bought a set of cheap (£20) Seat steel wheels, alas they didn't fit. Then a set of Passat wheels came up for £80 with decent tyres. Happy days.
Took it for mot in June 16 and it failed on the four top suspension arms, a few bulbs, track rod end and gaitor,and front brake pads low.
Well I got all the bits and did it all, but when I came to fit the pads I found the calliper was seized. I slightly blindly ordered a new calliper and thought bargain at £29. Well it would have been if it had of fitted.
Again the car got put on a back burner until a couple of weeks ago when I moved the car over the road so I had to walk past it everyday. To cut a long story short I didn't know there were two types of calliper that could be fitted (ATE or Lucas) to the B5, but with some friendly advice on here I sussed it and ordered the correct calliper. Well just for good measure the off side was also siezed solid so I ordered another new one.
The (wrong) Lucas calliper:
The discs had also gone past the minimum thickness, so I ordered a new set while I was it it. Having heard not so positive things about Pagid parts not being genuine from a well known supplier I opted for Brembo discs.
Having fitted the new front brakes I asked the other half to help me bleed them out. Well after not much happening after trying 5 -10 mins and I can hear the peddle being pushed up and down, I'm thinking surely the master cylinder can't be shot now as well, I go round to find she's pumping the clutch pedal.
Anyway got it all bleed out and changed a wiper blade and got it in for mot on Friday. Happily it is now mot'd
My plans for the car are to keep it fairly standard as a cheap back up car.
Next on the list to do are:
Cam belt and tensioner
While I'm there I'll do the water pump, thermostat and Polly V belts and check the engine mounts. While the guy was doing the mot, he lifted the front of the car and while the front of the car lifted, the front of the engine didn't lift. Not sure how that occurred.
Oil and filter (wanted to do before, but no oil filter so just dropped the oil, and will do the oil and filter and in a thousand miles or so)
And then every 3000 miles after that.
Diesel filter
Air filter
Also need to do the air pump for the central locking (and windows?) Which I've ordered today.
Will also change the gearbox oil when I can.
Once the cam belt is done it will be nice to actually drive it lol.
Diesel filter
Air filter
