mattandrew
Ive had the forge CAI fitted a month or so now and the ugly engine bay has annoyed me since. I looked into after market engine covers and decided against them so came up with the plan to butcher the original OEM cover. So I can put the car back to standard I purchased a spare engine cover from ebay for £50 as a new one from audi is about £130.
Heres the engine bay before with the CAI fitted, its not the best pic but you all know how ugly they look with the original cover removed.
I set to butchering the engine cover after I made the first few incisions
It would of been a bit to much hard work for the dremel so decided on the 9 inch angle grinder, bit over the top but did the job a treat.
after a few trial fits and a bit more cutting, the finished job
The modified cover uses the existing two front mounting points. I used a strip of double sided sticky foam along the back edge. The underside back edge sits across the top of the coil packs. I then used a cable tie to secure the cover down
The finished product fitted to the car
