so, Just for Leigh:
#BigGayWingV2
Lots of marking was done. Lots of measuring, and everything checked twice before any final holes were drilled in the tailgate.
The top 2 brackets are now drilled, and held here with temprary bolts. I'll either countersink and flush in some bolts, or buy some half smart dome heads if I'm feeling lazy.
Lower brackets at this stage are measured up and taped into position. They won't be drilled and finalised until I have the finished brackets ready to install permanently.
With these in place. It was time to work out the wing position.
Research has told me, that ideally, the wing wants to be as high up, and as far back as possible.
Something like GobStopper 2 demonstrates this nicely:
However, there comes a point where it's just too high and too far back, and despite working well, it looks Utterly rediculous. Imagine Gobstopper 2 in the Sainsburys carpark.....
I wanted it above the roof line in the air flow, but it's worth noting that airflow at this point won't be horizontal, it'll be following the line of the roof, which is on a slight downwards trajectory at the back of the car.
To ensure the wing sat above this roof line, the obvious answer was to stick something solid on this line, and rest the wing on it.
Enter - Wood!
2 bits of timber, 40mm thick. Ensuring that the lowest part of the wing sits 40mm above the roof line. Concrete block for good measure
I missed about with a few positions, forward, aft, up a little, down a little, and decided that I liked the 40mm vertical clearance, and decided on a figure of 250mm clear air between the back of the tailgate top, and the leading edge of the wing.
Again, the further back the better, but there comes a point where it looks like it's on a different car entirely if it gets too far away
It was of course, at this point, time for our old friend - CAD
After the CAD, I busted out the Jigsaw, and made a pair of these from 6mm MDF:
and then it was time to offer it up, minus the timber and concrete block, to get a first impression of what this might actually look like.
Ladies and gentlemen, may I present, named by Leigh Lewis: #BigGayWingV2
It's enormous, and utterly rediculous. I love it
I think the shape and size suit the car a treat. It's clearly not subtle in any way, but who cares
The turn buckle adjustment system also appears to have worked a treat too:
Hopefully I'll have some more templates cut out to test this evening. Perhaps try a few positions. Then, when I've finalised the position I'll be sending a template over to my friendly expert RobinJI to CAD it up and have it laser cut in ali
