Right so.............................. Results..
Car was booked in 9-5 for the custom map for the hardware but I had it back by 12pm..
Heres the before run where it had no Hybrid turbo fitted and was running the stage 2+ APR file.
Made 375 HP and 386 FT LBS... Not a bad figure.
20150106_152615 by
Ya Beast......, on Flickr
20150106_152627 by
And heres the after with the turbo with no WMI.
20150106_152639 by
20150106_152646 by
Did around 6 runs to log the data... UNMAPPED it made 427 HP and 445 FT LBS on the APR stage 2+ map.
Turns out, the APR map adapted for it and has made figures beyond our expectations.
It ran consistent figures at 27-28 PSI, bang on what it is meant to and accurate A/F ratios too.
So all I got charged was £60 Dyno time instead of the £500 mapping time I was quoted as it simply didn't need mapped.
So if you do go down the TTE-420 route, APR's software by default, makes this turbo run to its full potential..
The car is a total animal now.. Honestly, if you are thinking of getting one..... Do it!! Worth the money by a long way.
