Hi all
Thanks for reading - appreciate it. I know there are many threads on the BRE 170 oil pump issues and I've read a fair number of them...
Someone kindly left a note on my car saying it was smoking, that they had the same car, and to check the oil pump. I know it's suddenly started using oil, and there is a distinct hiccup/hesitancy every so often - a bit like it drops a cylinder for a split-second then recovers.
Mine's a 2006 '56 plate B7 A4 TDiQ 170 BRE, and as I understood it (possibly incorrectly) the later B7 models switched to a revised oil pump design, to eliminate oil pump woes.
My question is, would a failing/defective oil pump cause the engine to burn oil? My limited understanding of the dirty diesel lump tells me that oil is only present for lubrication, so if the oil pump is on its last legs surely I'd be getting a very hot engine that struggled to rev etc? It pulls cleanly to 3.5k / 4k if pushed although I usually drive like miss daisy to help economy (short run to work on A roads then a slow stretch of M25/M4).
DPF regens have been frequent, and it feels more like the DPF is clogged and can't regen, so there's back pressure in the system as a result. I can probably access VCDS to confirm this if I buy someone a drink, and I have a scan gauge in the car to monitor oil pressure.
Any and all thoughts/comments/abuse gratefully received
Cheers all,
Lafarge
Cheers all,
Lafarge
