VAG CheckAWEsome GTI
    StompOn is offline Neutral
    Mar 2009
    West Midlands
    57
    Post Thanks / Like
    Vag Com Connection
    i have an audi 80 1994 tdi whislt checking out my throttle sensor i noticed i have the obd connection by the fuse's i fink its called obd ill b corrected if not im sure but also in the fuse box at the top in the engine bay i got the 2x2 connectioin aswell there wires going to them both so im kinda just wondering which one would be best to use? cus ill need to get the adaptor if i need to use the 2x2
    thanks
    Google Adsense Circuit advertisement
    Advertising world
    bearthebruce's Avatar
    bearthebruce is offline Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    277
    Post Thanks / Like
    Odd that they both would be there. Is it possible someone added the 16 pin DLC connector so they could use a OBDII tool without the 2x2? It's not hard to wire one in. But I was not aware that the factory put both in any cars. Our compatibility charts indicate that only the 2x2 style connection was present in the Audi 80. But .....
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    Mar 2009
    West Midlands
    57
    Post Thanks / Like
    yea thats what i thought but wen i took the panel off underthe dash drivers side to check my sensor there was the brown obd plug there which left me confused guess ill wait till my cable comes n try if it works and if so them ermmm its gona be one of them things nobody can answer i guess unless sumone else with an 80 wants to take the panel of n look themselfs? i can take a pic n post it up if that helps
