JBSBadger5
Results 1 to 9 of 9
    Boydie
    My VAGCOM Results - URGENT
    Hey guys, I have a few problems at the minute with my A3 below listed are my recognised fault codes
    I would appreciate some assistance with these and advice in what needs done - honestly, I am not willing to go to Audi for the work but will pay a specialist if I cannot do the work myself or among friends
    Thanks for looking
    Address 01: Engine Labels: None
    Part No SW: 03G 906 016 G HW: 028 101 136 4
    Component: R4 2,0L EDC 0000SG 5334
    Coding: 0000072
    Shop #: WSC 79431
    3 Faults Found:
    18359 - Radiator Fan 2 (V177): Movement Restricted / Jammed
    P1951 - 000 - - - Intermittent
    Freeze Frame:
    RPM: 840 /min
    Torque: 24.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.14 V
    Bin. Bits: 00000000
    Temperature: 85.5°C
    Duty Cycle: 9.6 %
    17075 - Fan 1 Control Circuit: Short to GND
    P0691 - 000 - -
    Freeze Frame:
    RPM: 882 /min
    Torque: 40.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.44 V
    Bin. Bits: 00000100
    Temperature: 15.3°C
    Duty Cycle: 9.6 %
    19558 - Motor for Intake Manifold Flap (V157): No Signal
    P3102 - 000 - -
    Freeze Frame:
    RPM: 0 /min
    Torque: 128.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.31 V
    Bin. Bits: 00000000
    Torque: 0.0 Nm
    Torque: 220.0 Nm
    Readiness: 1 1 0 0 0
    Address 03: ABS Brakes
    Cannot be reached ABS WORKS THOUGH
    Address 08: Auto HVAC Labels: 8P0-820-043.LBL
    Part No SW: 8P0 820 043 HW: 8P0 820 043
    Component: KlimavollautomatH11 0130
    2 Faults Found:
    01274 - Air Flow Flap Positioning Motor (V71)
    003 - Mechanical Failure - Intermittent - I presume this is my ECON fault and why ECON keeps coming on when I have the Aircon on?
    Freeze Frame:
    Fault Status: 00100011
    Fault Priority: 3
    Fault Frequency: 10
    Reset counter: 223
    Mileage: 110391 km
    Time Indication: 0
    Date: 2008.05.02
    Time: 13:24:59
    Freeze Frame:
    Voltage: 14.00 V
    Temperature: 26.5°C
    (no units): 165.0
    (no units): 31.0
    Temperature: 14.0°C
    65535 - Internal Control Module Memory Error
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 224
    Mileage: 110947 km
    Time Indication: 0
    Date: 2008.05.08
    Time: 10:40:17
    Freeze Frame:
    Temperature: 23.5°C
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.LBL
    Part No SW: 8P0 920 980 H HW: 8P0 920 980 H
    Component: KOMBIINSTR. VDO H25 0110
    1 Fault Found:
    01176 - Key
    008 - Implausible Signal - Intermittent
    what is this about?
    Address 46: Central Conv. Labels: 8P0-959-433.LBL
    Part No: 8P0 959 433
    Component: KSG H02 0040
    Coding: 008800186D288505485AC63000
    Shop #: WSC 06435
    Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Part No: 1K0 907 719
    Component: Neigungssensor 002 0002
    Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0010
    No fault code found.
    If anyone wants me to email them the full results sheet please let me know and I will sort it out asap!
    thanks
    Boydie
    Retest after plugging it into my own vagcom
    VAG-COM Version: Release 607.3-UD
    Sunday,15,June,2008,20:10:56
    Chassis Type: 8P - Audi A3
    Scan: 01 02 03 08 09 0F 15 16 17 18 19 22 25 36 37 42 44 46 47 52
    55 56 57 62 69 72 76 77 7D
    VIN Number: WAUZZZ8P54A083683
    Address 01: Engine
    Coding: 0000072
    Shop #: WSC 79431
    2 Faults Found:
    P0691 - 000 - -
    Freeze Frame:
    RPM: 840 /min
    Torque: 16.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.14 V
    Bin. Bits: 00000000
    Temperature: 60.3°C
    Duty Cycle: 9.6 %
    P3102 - 000 - -
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 9.35 V
    Bin. Bits: 00000000
    Torque: 0.0 Nm
    Torque: 220.0 Nm
    Aug 2006
    Magdeburg, Germany
    286
    Post Thanks / Like
    Update to the latest version of VCDS and post a complete Auto-Scan please. You can download it for free from our website.
    http://www.ross-tech.com/vcds/download/current.html
    Once you did post a new scan with the latest version I do have some more specifics for you.
    Sebastian @ Ross-Tech.com
    mattandrew's Avatar
    Sep 2007
    Up in the hills, Derbyshire
    958
    Post Thanks / Like
    I am getting the same errors as boydie, heres my full scan. I am already looking into the Auto Trans faults, its the engine ones im worried about
    VCDS Version: Release 805.0
    Data version: 20080616
    Saturday,28,June,2008,01:55:08:12592
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56 76 77 7D
    VIN: WAUZZZ8P54A114429 Mileage: 112380km/69829miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 AT HW: 028 101 145 3
    Component: R4 2,0L EDC G000AG 5689
    Revision: 12345678 Serial number: AUX7Z0CNFNQ043
    Coding: 0000078
    Shop #: WSC 66565 257 00032
    2 Faults Found:
    P0691 - 000 - -
    Freeze Frame:
    RPM: 798 /min
    Torque: 34.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.21 V
    Bin. Bits: 00101100
    Temperature: 90.0°C
    Duty Cycle: 9.6 %
    P3102 - 000 - -
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.16 V
    Bin. Bits: 00101100
    Torque: 0.0 Nm
    Torque: 92.0 Nm
    Readiness: 0 0 1 1 1
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 041 C HW: 02E 927 770 G
    Component: GSG DSG 0623
    Revision: 03149888 Serial number: 00000311140069
    Coding: 0000020
    Shop #: WSC 06435 000 00000
    2 Faults Found:
    17100 - Transmission Input Speed Sensor (G182): Implausible Signal
    P0716 - 000 - - - Intermittent
    18148 - Clutch Temperature Monitoring
    P1740 - 012 - Electrical Fault in Circuit
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103
    Coding: 0023174
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 E HW: 8P0 820 043 E
    Component: KlimavollautomatH12 0150
    Revision: 005784 Serial number: 8P0820043E
    Shop #: WSC 00000 000 00000
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 D HW: 8P0 907 279 D*
    Component: Bordnetz-SG 1.0 H27 0601
    Revision: 00027000 Serial number: 00000000327746
    Coding: A488DF00A2141000000000000000000000
    Part No: 8P2 955 119 A
    Component: Wischer WWS Audi350 0170
    Coding: 16711696
    Shop #: WSC 00000
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
    Component: Airbag 8.4ED H00 0130
    Coding: 0011602
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0013142
    Shop #: WSC 12345 123 12345
    Part No: XXXXXXXXXXX
    Component: E0221 H06 0030
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Revision: D07 Serial number: 224NCD07002592
    Coding: 0000403
    Shop #: WSC 00557 210 58459
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 B HW: 1K0 907 951
    Component: Gateway H08 0090
    Revision: 08 Serial number: 2400103B097EA9
    Coding: 3F0F0FC8070101
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D07 Serial number: AUX7Z0CNFNQ043
    Shop #: WSC 00340 210 01205
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 HW: 8P0 035 192
    Component: RNS-E HIGH EU H52 0650
    Revision: 07S Serial number: AUZBZ7D0300112
    Coding: 0209717
    Shop #: WSC 74004 146 15103
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
    Part No: 8P0 959 801 A
    Component: Tuersteuerger. H10 0010
    Coding: 0000120
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 E
    Component: EPS_ZFLS Kl.10 1202
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Coding: 188800186D288F0FC85AC65000
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
    Part No: 8P0 959 802 A
    Coding: 0000120
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0209717
    Address 76: Park Assist Labels: 8P0-919-283.lbl
    Part No SW: 8P0 919 283 HW: 8P0 919 283
    Component: Parkhilfe 4-Kan H06 0020
    Coding: 0001003
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 K HW: 8P0 862 335 K
    Component: FSE_255x BT H26 0340
    Revision: 00000000 Serial number: 00000005224949
    Coding: 0011422
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 C HW: 1K0 963 235 C
    Component: PTC-Element 0404
    Revision: 00600000 Serial number:
    Thanks in advance Matt
    S3Ibis White
    Factory RNE-E : Optics : Light/rain sensor : ILP : BOSE : Bluetooth : iPod : Privacyglass : FCA : Auto Dimming/folding mirrors : Park assist
    Mods RS6 grill : Buckets : 19" Bentleys : KW v3 coilovers : H&R ARB's : Autotech HPFP : Milltek TBE : RS6 FBMFSW : Facelift taillights & diffuser : TT vents : ITG Intake : Forge DV : SDS : Alpine ipod kit : Lamin-X : Revo stage2+ : Sachs clutch : Shortended Tailgate : Ibis Colour Coded Interior
    To do FullClosureMirrors
    Vagcom
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,538
    Post Thanks / Like
    There is a TSB for issues with V157 and it jamming. I had mine changed under warranty for the new fixed version. It can pop the fan control unit Fuse and also throw a code. Well it did on mine.
    As mine was dealt with under warranty, I'm not sure if you can clean a sticky one up or not. It is just after the EGR valve on the intake.
    That would explain the Fan Control Unit code too.
    Regards,
    Paul
    2005 Black A3 (8P1) S-Line 2.0TDi DSG (Ex-MarriedBlonde). Eibach Pro Springs, Koni FSD shocks and a few bling bits inside. HEX-USB+CAN Vag-Com. Gone but not forgotten - Revo 99 GTi Turbo, too much to list mod wise. - 92 Golf Gti Mark 2 16V.
    mattandrew's Avatar
    Sep 2007
    958
    Post Thanks / Like
    Quote Originally Posted by Gti Jazz Blue View Post
    Regards,
    Paul
    Don't know why I didn't look before (probably as the cars been at the stealers for a week getting the DSG sorted) but Ive found a blown fuse
    Fuse 8 Actuators/sensors (engine compartment), radiator fan, main relay for ignition coil
    Not sure what caused it to blow but it seemed to be causing the three problems I have.
    1. The condenser radiator fans not working
    2. Intake manifold fault which is an actuator/sensor
    3. ECON light is not coming on when vehicle is stationary - as the fans are now running.
    Going to keep an eye on the fans, and keep scanning for faults
    I wrote the above before reading Pauls reply, makes sense with it jamming and popping the fuse, if it does it again I will strip down and clean the intake flap up before buying a new one, a new intake flap is Ł212+vat and thats trade
    S3Ibis White
    Vagcom
    Aug 2006
    Magdeburg, Germany
    286
    Post Thanks / Like
    I 2nd that, question though is if you still have some sort of warranty on the car but you can always fill an accommodation request I guess...
    Jul 2010
    Post Thanks / Like
    Hi I have the same problem V157 engine light and emission is on. Mechanic replace EGR valve, clean throttle and delete faults, everything was fine. After 5 minutes light is back on. I am going to visit mechanic for further investigation but I don't want him to rip me off. Any idea what is the problem. Thank you
    18,288
    Post Thanks / Like
    Have you scanned the car for faults as yet, post the scanned faults log, not all of it just the faulting modules will do.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
