Urgent help needed regarding HALDEX controller....Vagcom
scott_johnson
UK
Address 01: Engine Labels: 8N0-906-018.LBL
Part No: 8N0 906 018 J
Component: 1.8L R4/5VT G 0004
Coding: 10710
Shop #: WSC 80179
WAUZZZ8LX21002834 AUZ7Z0A1887012
2 Faults Found:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 - -
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 35-00 - -
Readiness: 0000 0000
Address 22: AWD Labels: 02D-900-554.LBL
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
2 Faults Found:
65535 - Internal Control Module Memory Error
00-00 - -
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 56: Radio Labels: None
Part No: 8L0 035 195 H
Component: symphony II NP2 0151
Coding: 00201
Shop #: WSC 00000
2 Faults Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
44-10 - Short Circuit - Intermittent
00856 - Radio Antenna
36-10 - Open Circuit - Intermittent
Any 1 any ideas...... most importantly the haldex controll unit?????
Any ideas guys.... main faults found......
Sounds like you have a boost leak somewhere downstream of the turbo
I have seen the " Check DV " Code loads of times. Check for leaks and test the DV for VAC leak but its worth giving the MAF a clean too as a dirty or old MAF could give the same code. You could log the output too. (The two engine faults are linked so cure one and the other will clear too)
The Haldex code is a bit of a worry. Have a look at the wiring to the controller and the controller itself. Is it possible its got wet lately?
If you can't find any issues or breaks in the wiring, it could be an internal fault and will need replacing I think.
