Volks AutosSky Insurance
Results 1 to 9 of 9
    Apr 2012
    93
    VCDS BRAKE BLEEDING, help please ?
    hi all, can i bleed my brakes with vagcom? ive broken 1 of the small bleed nipples off the master cylinder, while trying to bleed my brakes, and i need to know if you can bleed them through vagcom without having to change the broken bleed nipple on the m/c ?, if so how ? is this the correct way VCDS (VAGCOM) ABS Bleed Procedure - uk-mkivs ?? anything else i need to know ? please help
    thanks in advance martin.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    All that's for is bleeding the ABS module after completly emptying the system. You need to fix that broken nipple, no electronic aid is going to get the air out of a broken MC
    Apr 2012
    93
    it was bleed a few months ago at a vw garage with vcds and it had the same broken nipple,so it can be done m8!, the garage is closed, ive got vcds,, any help ?
    Quote Originally Posted by Byzan Pics View Post
    Apr 2004
    12,520
    I know it can be done, what i'm saying, unless you've drained the system right out it won't bleed any better than the manual method. Give it a try, nothing to lose
    Apr 2012
    93
    I carn't do the manual method, 1 of the nipples is broken off the m/c, its bin done b4 so can defo be done , I just wanted a but off help with it ,as I'm not used to using vcds, thanks,
    Jan 2011
    Aberdeenshire
    646
    Bleed it manually - you'll have no probs
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    Apr 2012
    93
    have u read the thread m8? i carnt bleed manualy, 1 of the nipples is broke off the m/c. thanks
    Quote Originally Posted by PAULF View Post
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    bleed it manually its easy.
    Apr 2004
    12,520
    What we are all trying to tell you, is using the VDCS method will have no difference in bleeding than doing it manually. If the nipple is broken, fix it. Then bleed however you like
  1. brake bleed hell, help please,
    By HOTTIGGER in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2012, 15:22
  2. Brake bleeding help!
    By swatchuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st April 2009, 21:27
  3. Strange DIS warnings.. brakes / gearbox = help please?
    By imported_CurryMilkShake in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th March 2006, 16:39
  4. Porsche Brake Owners - Help Please
    By s3bow in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th June 2005, 21:24
  5. Brake Dust! Help Please????
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2004, 00:01
