bluequattro
hey guys, i have some issues with my 05 a3, my footwell lights have stopped working, these were fitted a couple of years ago, bought from robin a3, parts were good quality and were virtually plug and play when fitting, however there not working anymore, i have checked the bulbs and wiring which all seems good, in vcds there is a tick in the box for footwell lights fitted, i have read everything i can on here to try fix this but cant find a solution, vcds is also telling me that my heated seating isnt enabled which is strange coz the seats seem to be working ok, i would really appreciate any help or clues on these problems guys, i have included a scan log of my car .
cal
Thursday,03,May,2012,12:18:26:40122
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 22 25 37 42 44 46 47 52 55 56 76 77
7D
VIN: WAUZZZ8P76A008244 Mileage: 61340km/38114miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 BA HW: 028 101 184 7
Component: R4 2,0L EDC 0000SG 9882
Revision: 12345678 Serial number: AUX7Z0E4FNJ0EW
Coding: 0000172
Shop #: WSC 66565 257 00032
VCID: 63CED47DA24E991
No fault code found.
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 R HW: 1K0 907 379 R
Component: ESP 4MOTION MK60 0102
Revision: 00T12001
Coding: 0023170
Shop #: WSC 06314 000 00000
VCID: 41823EF51892EB1
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 J HW: 8P0 820 043 J
Component: KlimavollautomatH15 0200
Revision: 057817 Serial number: 8P0820043J
VCID: 336E643D522E491
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H36 1201
Revision: 00H36000 Serial number: 00000001901924
Coding: A18ADB26A214100000000000000000000008FE175C0200
Shop #: WSC 06314 123 08192
VCID: 40843BF11398E29
Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
5 Faults Found:
00156 - Control Circuit for Windshield Washer Pump
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 203
Mileage: 61341 km
Time Indication: 0
Date: 2012.04.29
Time: 12:13:00
Freeze Frame:
ON
Voltage: 14.30 V
ON
ON
OFF
OFF
OFF
02398 - Control Circuit for Rear Windshield Washer Pump
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 203
Mileage: 61341 km
Time Indication: 0
Date: 2012.04.29
Time: 12:13:00
Freeze Frame:
ON
Voltage: 14.30 V
ON
ON
OFF
OFF
OFF
02092 - Enabling Heated Seat
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 203
Mileage: 61341 km
Time Indication: 0
Date: 2012.04.29
Time: 12:13:00
Freeze Frame:
ON
Voltage: 14.30 V
ON
ON
OFF
OFF
OFF
00897 - Windshield Washer Pump (V5)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 203
Mileage: 61341 km
Time Indication: 0
Date: 2012.04.29
Time: 12:14:00
Freeze Frame:
ON
Voltage: 14.30 V
ON
ON
OFF
OFF
OFF
02091 - Rear Window Washer Pump (V13)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 203
Mileage: 61341 km
Time Indication: 0
Date: 2012.04.29
Time: 12:14:00
Freeze Frame:
ON
Voltage: 14.30 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
Component: Airbag 9.41 H11 3520
Revision: 91H1135 Serial number: 0037W0002GX7
Coding: 0071612
Shop #: WSC 06435 000 00000
VCID: 479620ED36B6D51
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004012
Shop #: WSC 12345 123 12345
Part No: XXXXXXXXXXX
Component: E0221 H07 0090
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 BX HW: 8P0 920 981 BX
Component: KOMBIINSTR. VDO H80 0460
Revision: D08 Serial number: 2253ID08000155
Coding: 0005414
Shop #: WSC 02327 210 01865
VCID: 8F2648CD9E46CD1
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 25001055188386
Coding: FD0F0FCA070101
Shop #: WSC 00847 210 80521
VCID: 285483519BE83A9
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 A
Component: HALDEX 4Motion 0105
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 2B5E7C5D8A1E111
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D08 Serial number: AUX7Z0E4FNJ0EW
Shop #: WSC 00752 210 91076
Address 37: Navigation Labels: None
Part No SW: 4P0 035 192 Q HW: 4P0 035 192 Q
Component: RNS-E HIGH EU H74 0660
Revision: 05S Serial number: AUZBZ7H0917674
Coding: 0205715
Shop #: WSC 61379 150 12711
VCID: 397256157042B31
2 Faults Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 203
Mileage: 61341 km
Time Indication: 0
Date: 2012.04.29
Time: 12:11:14
Freeze Frame:
Mileage: 61340 km
Count: 2904
Clock: 12:10
00850 - Control Output Active; Radio Amplifier
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 203
Mileage: 61341 km
Time Indication: 0
Date: 2012.04.29
Time: 12:11:14
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0050
Coding: 0000632
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H03 0040
Coding: 188000403F3F8D0D489AC63300
Shop #: WSC 00853 210 60571
VCID: F9F21615B0C2F31
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0020
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH25 0160
Revision: 00003 Serial number: 10000001242684
VCID: F0E42B31E3B8B29
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0000632
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 C
Component: Dynamische LWR H01 0010
Revision: 00000000 Serial number:
Coding: 0000002
VCID: 3A7049197544B89
Address 56: Radio Labels: None
Coding: 0205715
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 203
Mileage: 61341 km
Time Indication: 0
Date: 2012.04.29
Time: 12:11:14
Freeze Frame:
Mileage: 61340 km
Count: 2904
Clock: 12:10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 203
Mileage: 61341 km
Time Indication: 0
Date: 2012.04.29
Time: 12:11:14
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 A HW: 8P0 919 283 A
Component: Parkhilfe 4-Kan H09 0010
Revision: 00H09000 Serial number: 00067824820513
Coding: 0000003
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 H HW: 8P0 862 335 H
Component: FSE_255x BT H21 0290
Revision: 00000001 Serial number: 00000000444265
Coding: 0011402
VCID: 3B7E4C1D7A7E811
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D5A7245B40A1F1
End ---------------------------------------------------------------------
cal
Chassis Type: 1K0
7D
Coding: 0000172
Revision: 00T12001
Coding: 0023170
Coding: 00062736
Shop #: WSC 06314
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 203
Mileage: 61341 km
Time Indication: 0
Date: 2012.04.29
Time: 12:13:00
Freeze Frame:
ON
Voltage: 14.30 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 203
Mileage: 61341 km
Time Indication: 0
Date: 2012.04.29
Time: 12:13:00
Freeze Frame:
ON
Voltage: 14.30 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 203
Mileage: 61341 km
Time Indication: 0
Date: 2012.04.29
Time: 12:13:00
Freeze Frame:
ON
Voltage: 14.30 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 203
Mileage: 61341 km
Time Indication: 0
Date: 2012.04.29
Time: 12:14:00
Freeze Frame:
ON
Voltage: 14.30 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 203
Mileage: 61341 km
Time Indication: 0
Date: 2012.04.29
Time: 12:14:00
Freeze Frame:
ON
Voltage: 14.30 V
ON
ON
OFF
OFF
OFF
Coding: 0071612
Coding: 0004012
Coding: 0005414
Coding: 0000001
Coding: 0205715
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 203
Mileage: 61341 km
Time Indication: 0
Date: 2012.04.29
Time: 12:11:14
Freeze Frame:
Mileage: 61340 km
Count: 2904
Clock: 12:10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 203
Mileage: 61341 km
Time Indication: 0
Date: 2012.04.29
Time: 12:11:14
Coding: 0000632
Coding: 0000632
Coding: 0000002
Coding: 0205715
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 203
Mileage: 61341 km
Time Indication: 0
Date: 2012.04.29
Time: 12:11:14
Freeze Frame:
Mileage: 61340 km
Count: 2904
Clock: 12:10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 203
Mileage: 61341 km
Time Indication: 0
Date: 2012.04.29
Time: 12:11:14
Coding: 0000003
Coding: 0011402
