Personally I don't like that the reply button defaults to a "quick reply". I always use the "advanced reply" with smilies etc.
Would it be possible to have a normal and quick reply button option?
I'll see if I can either change the behaviour of the existing button, or add another, shortly. It might become academic as I'm planning to make changes to the Quick Reply box which might make that all the more usable... Will keep you posted, but this is a P2 issue at the moment. (Sorting Quick Reply out is the P1 part of it)
And why are the smilies all bunched up at the side and stretch down the page over buttons etc?
There's no space allocated for them.
I'm just waiting for an issue to be cleared up with the hack to sort this, and then I'll stick it back in and the smilies should be a lot easier to access.
My information panel in the top right of each post (Join Date, Location, Posts etc) seems to go a bit off-kilter at the last line, there is a "1" infront of the "Thanks"
In short, vBulletin doesn't like you. Only joking! I'm not quite sure why that's happening, but I'll look into it as soon as possible...
The classified section is screwed up and practically unreadable.
This was this mornings' P1 issue, and should be resolved now - also any previous niggles with the Classifieds being tempremental sometimes should be sorted too.
Two from me, lack of smileys button on quick reply as mentioned by Mark in the other thread, and the line between a post and the sig isn't prominent enough, I keep finding myself reading sigs as if they're a new paragraph.
As above, smilies should be tidier in the very near future; and I'll deal with that line once I've finished hacking at the Quick Reply box.
When your looking through the new posts, I find it difficult to work out which section the thread is from. It was much easier when the 'section' had there own column.
Ryan
I'll look into this, but I'm not sure it's going to be straightforward to sort out. Will keep you posted....
Yes, it works that way, but there use to be a 'GO' button next to it to go straight back to the index of the forum you was in, which was damn handy!
I know it's one extra click (but it looks like vB sacrificed it for the benefit of quicker navigation to other useful areas), but if you click the quick navigation drop-down, and just click Forums Home - does that work OK?
How come I can only search from todays threads, ie put boost in the search forum and only get one or two responses. Also how do I find my stats to be able to see threads I have started in the past.
Looking much better though.
This is most likely because of the mahoosive task of refreshing the database's post cache; the situation should right itself - but if you're still having problems in another 24 hours I'd really appreciate a PM
Like Nattie has already mentioned, old posts pre-upgrade are no longer visible. If you view a certain users posts it only displays the ones which were made on the new platform. This is also true of the general search function.
As above...
Cheers,
Rob.
