Sky InsuranceAH Fabrications
Results 1 to 8 of 8
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,021
    RNS-d Firmware Update
    Thought i'd do a brief thread on how to update your firmware on your RNS-d unit.
    1, Download the firmware here (I will try and keep a copy of this program on my harddrive, just in case that link breaks.)
    2, Burn the files to a CD, close session and slowish. I burnt mine at 16x and it worked.
    3, Make sure the unit is off. Press and hold the 'Navigation' Button and the 'Flag' Button while turning the unit on. Keep these pressed until you see the below screen.
    4, Eject the Navigation CD and insert the firmware update CD.
    5, Move the selection to 'Start Control Unit' and you should see 'Current Software' and 'CD Software'. Like in the pic.
    6, If the CD software is newer than the current software, press the right knob in to start. You should see the below image.
    7, The will complete the installation and restart. It will then start updating the graphics.
    8, It will complete, restart and say it was successful. Take the firmware CD out and insert your Navigation CD.
    9, wait a couple of minutes for it to update and do the final stages. My languide went to german or something. If you go to Navigation, press mode, you will be able to change it.
    Hopefully that works for everyone else the same way it did with me.
    I started the update and then went for a long drive, to make sure it never ran the battery flat mid update.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Feb 2013
    I have a problem, when installing the update my daughter pressed something and it stopped and now it says timeout error...
    is there anything i can do?
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,021
    Quote Originally Posted by hugo. View Post
    Try again and make sure no one touches a button?
    Feb 2013
    Quote Originally Posted by ScottB5 View Post
    The problem is that when i turn the rns on it shows a. Blue screen saying timeout error, how do i restart the process?
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,021
    If the CD is still in the unit.
    Turn it off and hold the 'Navigation' Button and the 'Flag' Button again and see if you get the menu at the start.
    I think you can reset the RNS unit via VCDS.
    Feb 2013
    I tried the keys, but with the radio off when i press the navigation the display says it will download from the cd and then "timeout Error"
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,021
    Re: RNS-d Firmware Update
    Is that instant?
    Power off, hold the keys, power on and then time out error?
    What happens when you just turn it on?
    Feb 2013
    Is that instant?
    The same
  1. Current RNS-E Firmware
    By stevehall in forum Satellite Navigation
    Last Post: 5th March 2010, 10:45
  2. A6 MMI Software/Firmware updates...
    By madmac in forum In-Car Entertainment
    Last Post: 17th October 2008, 00:09
  3. RNS-E Firmware?
    By Khufu in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd September 2008, 19:42
  4. RNS-E Software update
    By danc in forum In-Car Entertainment
    Last Post: 24th July 2007, 17:08
  5. RNS-E dvd updated discs question?
    By mickel5 in forum In-Car Entertainment
    Last Post: 27th February 2007, 22:14
