01435 - Brake Pressure Sensor 1 (G201): Electrical Fault in Circuit
Jay.Ing
North West
Website
www.youtube.com
Hi guys, had my esp light come on this morning, got this code '01435 - Brake Pressure Sensor 1 (G201): Electrical Fault in Circuit ' Ross tech wiki says
Possible Causes
  • Brake Pedal Switch (F) faulty/jammed
  • Brake Pressure Sensor 1 (G201) faulty
Possible Solutions
  • Check/Replace Brake Pedal Switch (F)
    • See Measuring Blocks
  • Check/Replace Brake Pressure Sensor 1 (G201)
    • ABS Hydraulic Unit (N55) may need to replaced
    • Perform Brake Pump Bleeding
    • Perform Brake Pressure Sensor 1 (G201) Basic Setting
    • Replace Brake Electronics Control Module (J104)
im going to replace the brake pedal switch but does anyone know the location of G201?
I hope to god its not the Module!
Well after alot of digging and VAGCOM cumming up trumps again my ABS unit is kaputen!!!! Quote from audi = £900 (Thats with 40% off) :asskicking:
Any ideas as my cars only 2 months out of warranty! Has anyone had this problem before?
I would goto audi & say its only 2 months out of warranty would they do anything about it as they have been known to do something before when 3 months out of, also check for 2nd user unit mate as there's alot of kit out there that can perfectly be used on your car, just have to find the right version.
If you dont have luck with your dealer I have 2 email addresses you can use.
Did you bring any of this to the dealers attention before warranty ended?
Cheers. I will let you know how i get on for the email addresses!
The ABS failed on Friday, I was actually on the way to the dealership for a service! I swear they must have a remote somewhere with a big random fail button on it!
