I've installed, aftermarket by AUDI original spare part (retrofit) steering wheel command; but at authorized AUDI workshop was not able to activate voice command.
This is the question:
I'd Like to know if Can I activate VOICE command onto my AUDI A3 8V (sportback edition) SportBack 1.6 that come with MMI basic 5.8" sat-nav, Bluetooth handfree e steering wheel command, but not voice command and "*" key is not coded.
Tuesday,08,July,2014,22:34:26:14849
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.7.0.0
Data version: 20140601
VIN: WAUZZZ8V8DAXXXX License Plate: XXXXXX
Mileage: 20515km-12747mi Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WAUZZZ8V8DAXXXXXXX Mileage: 20515km-12747miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CLHA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 AL HW: 04L 907 309 B
Component: R4 1,6L EDC H22 5516
Revision: 84H22---
Coding: 02190012032401092000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM16TDI01104L906021AL 002009
ROD: EV_ECM16TDI01104L906021AL.rod
VCID: 6FEBA25FB6A70D4286-803A
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Revision: 00000000 Serial number:
Coding: 12F162A220270A740180060401C82548460450806080A4F20259000405
ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 7DF78817ECCB6FD204-8028
Address 08: Auto HVAC (E87) Labels: 8V0-820-047.clb
Part No SW: 8V0 820 047 B HW: 8V0 820 047 B
Component: AC Manuell el H09 0031
Revision: 20017000 Serial number: 00000000015064
Coding: 03000104002000001000000000000100
ASAM Dataset: EV_AirCondiFrontManAU37X 008016
ROD: EV_AirCondiFrontManAU37X.rod
VCID: 35675037947B77928C-8060
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 Q HW: 5Q0 937 084 Q
Component: BCM MQBAB H H14 0106
Serial number: 00011311200381
Coding: 04000A42C2C1227D03844000001C07A8000C000000000000000000000000
ASAM Dataset: EV_BCMCONTI 010001
ROD: EV_BCMBOSCH_AU37.rod
VCID: 468527FBF99DEC0A15-8013
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119
Component: WWS370 130412 041 0580
Serial number: 130415184616
Coding: 0A47F7
Subsystem 2 - Part No SW: 8U0 955 559 A HW: 8U0 955 559 A
Component: G397_RLS H06 0002
Serial number: 20112867
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 L HW: 8V0 941 531 L
Component: E1 - LDS MQB H05 0032
Serial number: 05 03 2013 00000197
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 A HW: 5Q0 919 283
Component: PARKHILFE 4K 009 0026
Revision: -------- Serial number: 60831310802177
Coding: 0000040001
ASAM Dataset: EV_EPHVA14AU3700000 002015
ROD: EV_EPHVA14AU3700000_AU37.rod
VCID: 377B5A3F8E7785829E-8062
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R017KNJ
Coding: 98CCC0000C0000005C540000004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_AU37.rod
VCID: 4B9316CFE2FF1162CA-801E
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 001 604 13
Component: SideSensor_Df 001 0887
Serial number: 35767000000A39309C0V
Coding: 2D2D2D
Crash sensor for side airbag; passenger side:
Subsystem 2 - Part No SW: ----------- HW: 480 001 604 13
Component: SideSensor_Pf 001 0887
Serial number: 358670000000279D0D0U
Coding: 2D2D2D
Crash sensor for side airbag; rear driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 400 304 13
Component: SideSensor_Dr 001 6149
Serial number: 3516502C50FEA2160304
Coding: 2D2D2D
Crash sensor for side airbag; rear passenger side:
Subsystem 4 - Part No SW: ----------- HW: 480 400 304 13
Component: SideSensor_Pr 001 6149
Serial number: 3526502C70FEA211930B
Coding: 2D2D2D
Crash sensor for front airbag; driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 401 503 13
Component: FrontSensor_D 001 6149
Serial number: 35565029B0FAE894331R
Coding: 2D2D2D
Pedestrian protection crash sensor; driver side:
Subsystem 6 - Part No SW: ----------- HW: 480 401 604 13
Component: PedP_Sensor_D 001 6149
Serial number: 2286502A70FAE8A2F0B+
Coding: 2D2D2D
Pedestrian protection crash sensor; passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 401 604 13
Component: PedP_Sensor_P 001 6149
Serial number: 22965029D0FAE8A5530W
Coding: 2D2D2D
Center pedestrian protection crash sensor:
Subsystem 8 - Part No SW: ----------- HW: 480 401 604 13
Component: PedP_Sensor_C 001 6149
Serial number: 2306502C90FBDE34C0B-
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 C HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 20041308490755
Coding: AE08
Shop #: WSC 30488 000 1048576
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 3A7D430BBD6598EA61-806F
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 8V0 920 870 B HW: 8V0 920 870 B
Component: KOMBI H24 0570
Coding: 07A40A002A80000804006800000000
ASAM Dataset: EV_DashBoardVDDMQBAB 008026
ROD: EV_DashBoardVDDMQBAB_AU37.rod
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 5Q0 907 530 J HW: 5Q0 907 530 F
Component: GW MQB High 125 1126
Revision: -------- Serial number: 0000529803
Coding: 030100F40B0876005B000248080B00000001000000000000000000000000
ASAM Dataset: EV_GatewLear 008010
ROD: EV_GatewLear_AU37.rod
VCID: 3879590383698AFA97-806D
Alternator:
Multifunction unit control module:
Subsystem 2 - Part No SW: 8U0 951 528 HW: 8U0 951 528
Component: E221 - MFL H02 0014
Serial number: 06 01 2014 B1288208
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004051251001
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 12041303110049
Coding: 001C0E205C00040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXKLO.rod
VCID: 3F8B321FA647BDC256-806A
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 81
ASAM Dataset: EV_SteerAssisMQB 008022
ROD: EV_SteerAssisMQB.rod
VCID: 3D774817AC4BAFD244-8068
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 06041306071109
Coding: 001C06205E00040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXKLO.rod
VCID: 3E754F1BA14DB4CA5D-806B
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0070
Revision: -------- Serial number: --------------
Coding: 018A000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: 75E79037D4FB37924C-8020
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8V0 035 864 B HW: 8V0 035 864 B
Component: MU-S-N-ER 040 0420
Serial number: A3F00703143183
Coding: 01730301FF00000021110001000A00002F0004440100010006
Shop #: WSC 62665 001 1048576
ASAM Dataset: EV_MUStd4CPASE 002018
ROD: EV_MUStd4CPASE_AU37.rod
Engine Control Module 2:
Subsystem 1 - Part No SW: 8V0 919 866 A HW: -----------
Component: ECE 2013 --- 0021
Serial number: --------------------
Seat Adjustment Driver Side:
Subsystem 2 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H48 0013
Serial number: AUZ8Z9DY3004UU
Sound System:
Subsystem 3 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000006031300010138
End-------------------------(Elapsed Time: 03:38)--------------------------
some questions:
in 5F module I've changed the last number from 4 (orginal one) to the actual 6. with this I can see the VOICE menu (SDS) in the MMI and the function is ok, but only for minutes. Pushing the SDS key (with icon face), beep, a windows is displayed, I talk and my car listen to me. But when I switch off the car, and than switch on, the function is lost. When I push the key of SDS, non beep, and no ear, I only can see a windows with the icon face, but nothing more. The MMI Voice menu is still there.
Another strange thing is that the " * " was not coded. Nothing appen when pushing it.
So I've found this coding:
5F: Adaptation
(77)-Vehicle function list BAP-MFL_Jocker_0x34 - Activated
(1)-Vehicle function list CAN-MFL - Available
(146) Vehicle menu operation MFL_Jocker - Activated
With this setting I'm able to set " * " but the VOICE MENU SETTING is SETUP -> CAR -is not more shown even the code for this is unchanged.
This are my debug log:
Code:
Address 5F:8V0 035 864 B recoded (ADP-(77)-Vehicle function list BAP-MFL_Jocker_0x34) from not activated to activated Tuesday,08,July,2014,23:11:31:14849
Address 5F:8V0 035 864 B recoded (ADP-(1)-Vehicle function list CAN-MFL) from Not available to Available Tuesday,08,July,2014,23:12:35:14849
Address 5F:8V0 035 864 B recoded (ADP-(146)-Vehicle menu operation-menu_display_MFL_jocker) from not activated to activated Tuesday,08,July,2014,23:16:58:14849
Address 5F:8V0 035 864 B recoded (Long Coding) from 01730301FF00000021110001000A00002F0004440100010006 to 01730301FF00000021110001000A00002F0004440100010004 (62665/001/1048576) Tuesday,08,July,2014,23:27:58:14849
Address 5F:8V0 035 864 B recoded (Long Coding) from 01730301FF00000021110001000A00002F0004440100010004 to 01730301FF00000021110001000A00002F0004440100010006 (62665/001/104857) Tuesday,08,July,2014,23:30:38:14849
Address 5F:8V0 035 864 B recoded (Long Coding) from 01730301FF00000021110001000A00002F0004440100010006 to 01730301FF00000021110001000A00002F0004440100010004 (62665/001/104857) Tuesday,08,July,2014,23:34:47:14849
Please, help me activating SDS
