Chris NottMonster Motorsport
    axelfols's Avatar
    Jan 2005
    Edinburgh
    124
    Door light Switch Fault 1997 A8
    Hi, Can anyone tell me where the door light switches are located?? My nearside door does not operate the interior light when opened and i cannot seem to find the switch as i'm sure it must only be a case of replacing a faulty switch.
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    912
    think it's part of the lock mechanism
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    It is indeed part of the lock mechanism and they are very prone to this fault.
    They often get clogged up with grease when people lubricate the locks.
    It is often possible to fix without changing the lock if you use some electrical solvent and give the micro-switch a good clean.
    I'm an optimist but I don't think it helps much.
    A3 8P 2.0TDi S-Line Sportback DSG
