EM TuningJMB Retrofits
Results 1 to 23 of 23
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,613
    Any Electricians/Plumbers out there?
    Recently, when my washing machine goes into the spin dry cycle, it pops one of the main fuses in my garage, but the fuse that's in the plug doesn't go?
    Does that mean it's time for a new washing machine(it's around 7-8 years old) or does anyone have a clue why that's happening?
    I'd also like to point out that the washing machine resides in an extended part of the house, or the utility room as some would call it, so could it be a wiring problem?
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    get an extension lead and and plug it in to the house then plug it in and see if it does the same thing .........sounds like washing machine the condenser could be knackered
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    It could be the pump on the washing machine as well .have the clothes been very wet lately after finishing the cycle.have you emptied the catch filter before the pump
    FM I sound like a sweetie wife
    Urq RR
    S2 Coupe...RS2 +
    A4 AVANT TDI
    Justincredible's Avatar
    Dec 2006
    Kentucky--USA
    170
    Very rarely dose wiring ever go "bad" unless its been damaged some how...
    With that said...I need some more info.
    What size fuse is in the main box that keeps blowing?
    Is it actualy a "fuse" or "breaker"?
    How far away is the washing machine from the main fuse/breaker box?
    The "fuse" that you refer to as being "in the plug"....are you sure this isnt a GFCI trip unit? (Does it have a TEST and RESET button on it?)
    The reason I as is because I've never heard of a fues being "in the plug".
    BTW...
    In case your wondering....I am an Electricial Engineer Tech. and licensed Master Electrician of 8 years.
    timps's Avatar
    Shakersville
    Oct 2005
    Shakersville (Bury)
    235
    In the UK every appliance has a three pin plug with a fuse built in due to the the ring main principal in the US (where I assume your from) you dont hence the confusion in the US you have individual breakers/fuses supplying each socket.
    The maximum rating of fuse in your washing machine plug can only be 13 amps so if your main fuse blows first it has to be .
    1) a lower rated main fuse less than 13 amp .
    2) the same rated main fuse but more sensitive e.g MCB rather than a fuse wire.
    3) overload on the total circuit too many things running at once.
    The washing machine could still be faulty but for it to blow the main fuse first it has to be :- lower rated, more sensitive or overloaded with other appliances /load for it to go first.
    Dec 2006
    Kentucky--USA
    170
    Quote Originally Posted by timps
    That interesting...
    Are you saying that each branch circuit (to include general purpose and dedicated circuits) is not individualy protected via a breaker or fuse in the main breaker box?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,613
    It's a breaker in the main fusebox that keeps popping, I'm not sure how the wiring is done in the utility room, but the sockets where the plug goes into is hidden under a small sink and bolted to the cabinets. I'm thinking it's an overload of the circuit, cos the lights, washing machine and freezer is getting the power from one source I would have presumed.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,613
    It's late over here, I'm going to try the 'use the extension' idea as suggested by rev tomorrow.
    timps's Avatar
    Shakersville
    Oct 2005
    Shakersville (Bury)
    235
    That interesting...
    No they are protected.
    But legally you cannot buy a UK 3 pin plug without fuse protection built in and the maximum fuse you can buy to fit in this plug is 13 amps.
    The reason is we use a ring main circuit which is a complete loop of usually 2.5 mm cable which is protected by a 30 A main fuse in the fuse box with the wire returning back to the same 30 amp fuse, a number of sockets are daisy chained together on this loop & the individual appliances are further protected by the plug fuses.
    We also have spares or radial circuits which are non returned circuits protected by a smaller fuse or thicker wire.
    But because the ring circuit exists in many homes it does not matter which system you use you cannot buy an un-fused 3 pin plug in the UK by law.
    Dec 2006
    Kentucky--USA
    170
    Thats pretty cool...
    Your 2.5mm wire is the equivalent to our #10AWG wire which is rated at 30 amps (excluding volatage drop, ambiant temp, and free air space, etc).
    I really like the "ring circuit" idea...
    We dont use anything like that at the commercial/residential level over here.
    But our utility grids and some industrial buss-duct systems are configured in that same manor. Provides a redundent supply in the event something happens at one end/side.
    See....Im learning something from you Europeans already.
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,885
    Joe, if it's 7-8 years old, it's time for a new one.
    2013 AUDI A3 SB S-LINE : 2.0 TDIQ 184 : GLACIER WHITE :
    : S-TRONIC : COMFORT PACK : SD SAT NAV : FOLDING MIRRORS : HEATED SEATS: RIGID BOOT LINER :
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    your utiity room should not have the sokets and the lights from the same breaker, it does sound like a overload problem more than a washing machine problem.
    try unplugging the freezer while you do a wash and see if the same thing happens.
    also whats the ampage of the breaker ??? it might have a spurious one fitted possibly even a 15 amp not a 30 amp one.
    I hate cuircuit breakers, much prefer my fuses, I know they are old school but they work well and if I want breaker protection I use one of those plug in jobbies.
    red to red black to black blue to bits
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,613
    Been using pretty much the same setup for 7-8 years i've had the washing machine, this problem has started most recently, when the weather has got cold, was out all day, so didn't try the other sockets. The other half is afraid to use the washing machine whilst i'm not there lol, so she's taken the laundry to the inlaws haha, it's a pain moving my damn car backwards a few feet, just to open the garage door to get to the damn fusebox!
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    If this has worked for years and is now just showing a problem its unlikely to be a wiring fault, but don't rule out a dodgy breaker, they do and can fail.
    I'd suggest there is some problem with the washing machine, possibly the heating element inside the washer as this has the highest load draw BUT If a washing machine on a 32 amp circuit is tripping an MCB out then its not an overload its a short circuit. the fuse in the plug top would go before the MCB on an overload.
    Its either a faulty MCB or a short in the machine, maybe a wire has worn through over the years and is causing a short.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,885
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    MMMmmm does not spin might solve the problem......
    Urq RR
    S2 Coupe...RS2 +
    A4 AVANT TDI
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Urq RR
    S2 Coupe...RS2 +
    A4 AVANT TDI
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,885
    Mrs Joes xmas present is sorted.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,613
    LOL, at least I can get around 3 quid for my current one huh?
    The main fuse now justs pops when I flick the damn thing on, something wrong there methinks, I'm just baffled that the 13A fuse in the plug doesn't go first?!
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Like I previously said (maybe you didn't read it) a fuse will only blow on an overload but a breaker will trip on an instantanous short. Much quicker than the fuse will melt.
    Chris
    See my images @
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,885
    Did you get this sorted Joe.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,613
    Quote Originally Posted by TDI-line View Post
    God I must have a short memory lol.
    I ended up getting a new Washing Machine Dan, and the problems have come back, so getting an electrician in is my new option, need to make a few calls tomorrow methinks.
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,885
    Lol.
