EM TuningJuicy
Thread: a4 tdi
    Feb 2008
    lancashire
    133
    Post Thanks / Like
    a4 tdi
    what engine code will a 1999 v reg a4 tdi 1.9 be anyone know ?
    Jun 2007
    6
    Post Thanks / Like
    hazard a guess at AFN
    Milton Keynes UK
    243
    Post Thanks / Like
    If its the 110bhp model then it should be the AFN engine as advised above.
    You should have a lable in the service book that states what engine code you have. If you have lost the service book then there is also a label where your spare wheel is located.
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    508
    Post Thanks / Like
    On the top of the plastic cambelt cover housing there should also be a bar-coded sticker which lists the engine code and number..........
    If its a '99 AFN the engine noise insulation cover should have a red letter 'i' on the TDi motif, although as the cover is so easy to remove it shouldn't be taken as 100% that the cover is original to the car...........
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Aircon+Climate /Royale blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
