WX51TXR
Polished Bliss
- Joined
- Mar 6, 2005
- Messages
- 1,452
- Reaction score
- 16
- Points
- 36
- Location
- AB51 0TH
- Website
- www.polishedbliss.co.uk
This month it's simple; spend over £65 from midnight tonight, and you'll get a 1 litre bottle of Menzerna PO91L included with your order for free (with no extra postage to pay either). This offer will last only while stocks do.
Menzerna PO91L
Menzerna Intensive Polish is designed to restore dull, oxidised, neglected paint and remove major paint defects (severe swirl marks and scratches). This polishing compound has revolutionised the paint correction process, as it is capable of removing severe swirl marks and deep scratches with little or no surface hazing. These characteristics are rare, as hazing is a normal result of compounding, and is typically removed by further polishing steps using increasingly finer polishes until a high gloss finish is restored. However, Menzerna Intensive Polish creates so little haze that it is often possible to go straight from compounding to adding wax or sealant protection without an intervening polishing step. In cases where an intervening polishing step is required (often on darker coloured cars), the amount of additional polishing required is significantly reduced, saving time and effort. Unlike many polishing compounds, Menzerna Intensive Polish is water-based. It does contain a petroleum distillate, but this serves as a lubricant, not a solvent, meaning that it will not soften or affect the curing of fresh paint. Also unique is the fact that it contains no fillers of any kind, meaning that defect removal is permanent rather than temporary. The abilities of Menzerna Intensive Polish are further enhanced when used in conjunction with Lake Country 6.5" CCS Technology Light Cut Pads. Menzerna Intensive Polish may be applied by hand or by machine polisher, and although the best results are obtained using the latter, it remains one of the finest and most effective hand polishes currently available on the market.
Cut: 5/10 Gloss: 7/10
Menzerna PO91L
