Volks AutosSky Insurance
Results 1 to 11 of 11
    Jun 2009
    Hartlepool
    183
    BMW645 enhancement detail
    An enhancement detail on a BMW645 which due to the amount of swirls was being robbed of any depth to the pant or reflections. Which stands out even more under the halogen spot light when doing the 50/50 shots
    And the dirt build up and zebra stripes on the roof was also letting the car down
    Products and equipment used
    Uber microfiber towels
    Chemical guy’s woolly mammoth drying towel
    3m yellow pads 150mm 75 mm
    3m blue pads 150mm 75mm
    140 mm Lake county ultimate last stage Pad
    Halogen site lights
    Makita rotary polisher
    DA Polisher
    Scholl s17+
    Scholl S40
    Carpro eraser
    303 convertible top cleaner
    303 high tech fabric guard
    Blackfire all finish paint protection
    Blackfire Midnight sun wax
    3m masking tape
    Meguiars APC
    Costco microfibre towels
    Meguiars hyper dressing
    Valet pro citrus bling
    Bilt Hamber AutoWheels
    Valet Pro PH neutral Snowfoam
    Valet pro tyre dressing
    AMDetails AMbubbles
    Bilt Hamber clay bar
    Autosmart Tardis
    Various brushes
    Kranzle pressure washer
    Carpro Sheepskin wash mitt
    Carpro Dlux
    Noodle wash mitt
    Carpro Lambs wool wash mitt
    Poorboys microfibre clothes
    Uber buffing clothes
    Autobrite Snow foam gun
    Chemical guys Jetseal 109
    Autobrite Repel
    Autosol metal polish
    00 grade wire wool
    Some photos of the car before I start
    The roof
    The car was then given its first coat of snow foam whilst this was dwelling I went round the car using APC in a foaming head bottle cleaning the fuel filler area and various gaps and grills. The snowfoam was then blasted off with the pressure washer, and then the car was given another coat of the same mix snowfoam and then cleaned off again at this point it started to rain so the car was brought into the unit.
    The car was washed using the 2 bucket method with grit guards in both buckets and a Carpro lambswool wash mitt.
    The car was then rinsed off using an open ended hose and I then went round the car with Tardis which was left to go to work before being wiped down with microfibre clothes. The car was then given a coat of Ironx again left to do its stuff before the car was washed doing using the pressure washer.
    The car was clayed using citrus bling and water mix (10 to 1) and a Bilt hamber soft clay bar which helped to pull more contaminates from the paint work it was then rewashed using the same method and dried using the woolly mammoth. As it was still raining the wheels where left until I could get the car back outside but they where cleaned using Bilt Hamber AutoWheels which is another new product to me which I’m really impressed with as fronts of the wheels was just given a coat of this and then left to dwell for a couple of minutes then removed using the pressure washer, the inner face’s of the wheels are in a very poor state I think the owner is looking at getting them powdercoated in the original silver finish as the really let the final look of the car down this is something we will be able to offer as part of our detailing packages soon.
    The arches where next and they where sprayed with APC and cleaned using various brushes and a noodle wash mitt. They where then sprayed with Tardis which was left do its stuff whilst I moved onto the next arch before going back and being wiped down with a microfibre cloth.
    The roof was cleaned using the 303 cleaner which I did twice as the amount of muck and mold on the roof was unreal
    Before I started polishing the car I decided to go round and dress the arches using Meguiars hyper dressing
    A few 50/50 shots using my site lights
    Jun 2009
    Hartlepool
    183
    I then taped the car up and went round with various yellow 3m pads and Scholl s17+ polish, each panel was given a wipe down with carpro eraser after polishing to check finish and remove any polishing oils.
    After this I went back round the car with the Scholl s40 and a the 3m pads to give the finish a little more depth
    The Roof of the car was given its first coat 303 fabric guard which was left to dry over night before a second coat was added
    I then went round the car and applied a coat of Blackfire all finish paint protection using the DA and the lake county pad which was left before being buffed using Uber buffing towels.
    At the end of the first day
    Jun 2009
    Hartlepool
    183
    The car was given 2 coats of the Midnight sun wax leaving approx 60min between each coat again buffed using Uber buffing towels
    The plastic trim was dressed using Carpro Dlux which is a cracking product which a little goes a long way and gives a stunning finish.
    After this I ceaned the glass and gave them all 2 coats of Autobrite repel and also gave the arches another coat of hyper dressing and dressed the tyres using the Valet pro tyre dressing. Alloys sealed using 2 coats of Chemical guys Jetseal 109
    Exhaust was cleaned up using Autosol metal polish and 00 grade wire wool
    And a little beading shot
    Juicy Jen's Avatar
    Jen – Juicy Detailing
    Jun 2011
    County Durham
    835
    Nice work Shaun .... see your getting the unit up and running nice and quick.
    Just a side note some of the pictures were a little out of focus which makes then a bit difficult to see.
    Authorised Sponsor of Audi-Sport.net with exclusive offers for members
    2012 8P3 AKA The Green Goblin in Exclusive Java Green, Stage 1 Shark bite
    Jul 2011
    Teesside
    327
    You have your own unit now eh? Wow, Im impressed. From starting out doing this on your drive to setting up properly, yeah good on ya mate.
    Best of luck with your business.
    Ps. The BMW looks great
    Jun 2009
    Hartlepool
    183
    Quote Originally Posted by Juicy Jen View Post
    Cheers Jen i thnik i`ve killed my camera as i dropped it getting out of the car, need to go camera shopping asap
    Jun 2009
    Hartlepool
    183
    Quote Originally Posted by JDM82 View Post
    Cheers matey have a pop in sometime
    Jul 2011
    Teesside
    327
    Will do mate, where's your unit at?
    Jun 2009
    Hartlepool
    183
    North East Car Care
    Unit 1F Ullswater Road
    Longhill Industrial Estate
    Hartlepool
    TS25 1UE
    Jul 2011
    Teesside
    327
    Shaun, you sharing a unit with Jonathan, Retrofits?
    Jun 2009
    Hartlepool
    183
    Sure am matey
  1. Pink to red BMW enhancement detail
    By butler2.8i in forum Detailing
    Last Post: 8th April 2012, 18:10
  2. Modified VW Polo enhancement detail
    Last Post: 14th September 2011, 10:04
  3. Fiesta RS Turbo enhancement detail
    Last Post: 25th August 2011, 19:13
  4. Audi TT enhancement detail
    Last Post: 20th July 2011, 17:34
  5. Audi TTS - Enhancement Detail + Swissvax
    By Proshine in forum Detailing
    Last Post: 1st May 2011, 10:55
