Badger5Sky Insurance
Results 1 to 11 of 11
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    DVC 2ohm connection question
    Okay, so i got a Orion Hcca 15" dual 2ohm voice coil and an amp which is 1ohm stable @ 2000w rms sub is also 2000w rms, my amp is a mono block but has 2 x terminals, now i know both terminals output the same power, but which is the best way to hook the sub up. 1) use both terminals and run wires to each coil? or 2) use one terminal and bridge the 2 voice coils to 1ohm? would their be any difference in the two, i imagine that the proper way is run 2 voice coils to 1 ohm, but thought i would just double check
    Passat B5.5 tdi....... big plans to come
    Audi A3 8p motor way work horse
    Nissan Skyline r33 gts-t ..... my mid life crisis fun car
    Dec 2006
    barnsley
    1,016
    are you certain the subwofer you have bought is dual 2 ohms ?
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    its got 2 voice coils and they both say 2 ohm lol
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    Dec 2006
    barnsley
    1,016
    the reason i ask is because if the information isnt correct beforehand and it isnt dual 2 ohm coils it can very very easilly fry both the
    amp and sub
    the way you connect it is this
    positive to positive with one wire to the first positive terminal then piggy back with the same wire gauge to the second positive speaker terminal
    negative to negative with one wire to the first terminal then piggy back with same gauge wire onto the second negative speaker terminal
    this way will give you a 1 ohm load which is the maximum your amplifier is reccomended to do
    i would also consider using an oscilloscope and test tones to set the correct gain
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    Quote Originally Posted by dualmono21 View Post
    amp and sub
    cool will give it a go, I can set gain easily as i know the voltage of my stereo is 8v so i can just set gain to that cant I, besides, i dont think i will have it turned up that much as it will be too over powering until i got the rest of the system finished
    Dec 2006
    barnsley
    1,016
    no you cannot
    there are very very few headunits with 8 volts output and most of those only do it by using a line driver
    what are you using ???
    i will try to simplify this as much as possible you need to both check for clipping from your headunit and amplifier
    then match the gain between your headunit and amplifier
    you cannot do this by simply guessing or thinking you know
    what you have bought is a class d amplifier which while being a lot more efficient than a normal class a/b amplifier they are also more fragile
    certain things these ampifiers dont like
    voltage is one .... do not turn the amplifier on when you are down on battery power you will kill the amplifier
    do not clip the amplifier both on the input side and the output side again you will kill it very very easilly
    make sure the amplifier is secured properly inside the vehicle and make sure it is well ventilated
    if you dont the amplifier will vibrate and again you will kill it
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    Sorry, i ment 4v, it says in my stereo manual DEH-P800BT (Archived) - Pioneer Europe
    Dec 2006
    barnsley
    1,016
    to run this properly it needs setting up
    that way you can be cartain you are not going to damage anything when you fell like turning the volume up
    scope the headunit and see at what point does it clip and what voltage
    set this as the maximum on your headunit then scope the amplifier and check to see the maximum gain at that voltage
    then make sure you never ever go above this
    this will give you good clean reliable power
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    cool, will give it ago
  1. Bluetooth connection question (newbie alert)
    By Chadders in forum In-Car Entertainment
    Last Post: 11th October 2012, 19:57
  2. Connect ipod to Concert I stereo question
    By RobW in forum In-Car Entertainment
    Last Post: 19th February 2010, 23:39
  3. iPod Connectivity Question
    By Mr_Sixx in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th December 2007, 15:24
  4. iPod connection questions - A3 8L Concert
    By buckas in forum In-Car Entertainment
    Last Post: 30th August 2007, 13:03
  5. New TV & DVD-HDD Recorder - Connections questions.
    By jdp1962 in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 3rd June 2007, 19:26
