GNJAWEsome GTI
Results 1 to 7 of 7
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    270
    Post Thanks / Like
    8p 3DR Speaker size
    Chaps
    What size/wattage speakers are best for replacing the fronts running off the standard concert head unit
    and what size/wattage are best for replacing the rear running off the standard concert amp...the standard sub has been removed...
    and an uprated sub/amp will be fitted.
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    Fronts are 6.5" components with 1" tweeter
    Rears are 6.5" coaxials
    You'll need adapters to fit both fronts and rears
    Wattage is irrelevant as they don't make a speaker so puny that it would be overpowered by the 4 x 20w output from the HU & rear amp
    Be aware that if you have removed the stock sub then you have also removed the rear speaker amp (inside the sub), so if you are keeping the standard HU then you will have no feed to the rear speakers. You will need to either extract the amp from the old sub and reinstall it or add a small aftermarket amp to power the rears. Or better still forget about the rears altogether and spend more of your budget on front components, or even better still a decent amp to drive them.
    Alex Turner
  4. Thanks RobMorris thanked for this post
  5. #3
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    270
    Post Thanks / Like
    Cheers Andy
    Ive bought a set of 'CT25AU05 Speaker Fitting Adapter for Audi A3/A4 Front & Rear 165mm'
    Can I safely fit 6.5" 'mid bass' speakers? I know they have a larger magnet than normal speakers?
  6. #4
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    Should really have got the MDF ones. You need proper 2 way components, pretty much anything will fit
    Alex Turner
  7. #5
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    270
    Post Thanks / Like
    So if I have 2 sets of these DRAGSTER DM 6 165mm or 6.5” RMS power 80/max 150 Watt | eBay
    To replace my standard speakers - is it going to sound poop?
  8. #6
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    Yes, as said you need proper 2 way components and from a decent manufacturer, if you're on a budget then something like these Alpines:
    Alpine SXE-1750S
    Alex Turner
  9. #7
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    270
    Post Thanks / Like
    Another waste of money ive managed!
    Cheers Andy - il go for some proper 2 way components for the front doors...
    Are the midbass ok to chuck in the rear qtrs?
  1. Speaker Size
    By TripleD in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th March 2009, 17:30
  2. Front Speaker Size in the a3?
    By Tommy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th February 2009, 18:51
  3. 8p speaker size ?
    By SteveTDCi in forum In-Car Entertainment
    Last Post: 5th January 2008, 12:00
  4. Speaker size
    By albgut1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th September 2005, 10:36
  5. speaker size
    By a3kid in forum In-Car Entertainment
    Last Post: 7th June 2005, 22:36
