AH FabricationsVolks Autos
Results 1 to 18 of 18
    Jul 2011
    21
    help! mirrors not working
    Hi
    My 2008 a4 wing mirrors are not working. I can't adjust them from the switch on the drivers door.
    26,717
    Which feature isn't working, the mirror glass 4 way movements, folding, heated etc, need more info.
    Check door rubber for broken wires.
    Jul 2011
    21
    It's the mirror glass 4 way movement that's not working. Both doors not working.
    26,717
    Does it have electric folding?
    Check door rubber 1st for any broken wires.
    Jul 2011
    21
    Not sure if they are folding mirrors but they aren't folding at the moment. Had a quick look at the door rubber loom. How do you expose the cables easily
    Jul 2011
    21
    Just checked. They are not folding mirrors but they are heated
    26,717
    Whereabouts are you located?
    Jul 2011
    21
    Im in Lanarkshire. I had a look at the wires inside the rubbers. All of the wires looked in tact. The purple and white one in the passenger side was a little kinked.
    26,717
    Maybe the switch has become faulty, it hasn't got wet at anytime has it?
    Jul 2011
    21
    Not sure. I only bought the car a couple of days ago. How could I test to see.
    26,717
    Private or dealer?
    Jul 2011
    21
    Private
    Dec 2004
    133
    Have you checked the fuses. Full list of fuses and locations in handbook.
    A4 Avant 2.0TDI 143 Black Edition, Daytona, Alcantara, Heated Seats, Tech Pack, Advance Parking, Light Pack + full LED upgrade, Power Tailgate, S Line Sports Suspension
    Jul 2011
    21
    Checked the fuses too. Couldn't find one for the mirrors
    Dec 2004
    133
    Quote Originally Posted by lgu00174 View Post
    Front right door mirror fuse is located in Right Hand Side of boot behind trim panel. Centre block, fuse 9, number 1 being the closest to the boot and counting going toward the exterior of the car.
    Front left door mirror fuse is located in panel on LHS of dashboard, accessible with door open. Centre block, fuse 8, counting from top to bottom.
    Jul 2011
    21
    Just checked these fuses and they are ok. I've checked every fuse and they are ok.
    26,717
    Its going to need diagnosing with vcds 1st to see if the switch movements are being seen, but one little thing, I wonder if the switch connector has popped out, door card of job.
    Does the switch illuminate at night like all the others, if not then it could be this.
    Jul 2011
    21
    Problem solved. As suggested the mirror switch was not plugged in. Thanks everyone for your help.
  1. Roof Windows Mirrors NOT working ?? please help
    By pompeyclements in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th January 2012, 22:57
  2. Help, wipers not working!!
    By MrGrumpy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th June 2008, 16:10
  3. Folding mirror not working?
    By coyote in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th January 2008, 09:44
  4. Heated mirrors not working?
    By fallmonk in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd November 2004, 18:17
  5. heated mirrors not working.
    By moschino in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th January 2003, 17:14
