AH FabricationsSky Insurance
Results 1 to 8 of 8
    10
    B6/B7 differences
    As the title says, what are the main differences between the two.
    Is it a totally package or was the b7 an upgrade on the b6, are the engines the same (I know the 3.0 tdi power output is different but is that just the mapping?)
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,533
    B7 was a styling upgrade only of the B6.
    The only functional change is that the engine management diagnostics are done via CAN bus on the B7 because of a change in the regulations. SO new engine ECUs are fitted, some with new mapping.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    10
    Quote Originally Posted by PetrolDave View Post
    So a remap will see the same figures?
    68
    correct me if im wrong but wasnt the engine posistion also moved back in a bid to reduce understeer?
    A4 2.0 TFSi Quattro S-Line - Shark Peformance Stage 2 + Decat
    Good 2 B A Gooner's Avatar
    May 2009
    Chichester
    715
    Quote Originally Posted by dan_the_v8man View Post
    Your spot on Dan - They also used parts from the A6 to improve the handerlig etc.
    The B7 has a number of new engines also, the 2.0T and 2.0TDI are the best to go for.
    A quick search on the AutoExpress website will show you other things changed.
    May 2009
    Chichester
    715
    Quote Originally Posted by skiptowncat View Post
    I've driven both and the handling is a massive improvement over the B6, also if youre getting a diesel the 2.0 is a much smoother, more refined drive than the 1.9.
    The engines aren't available in the B6, such as the 2.0TDI's and 2.0 T Petrol's - You can't map a 1.9 to become a completely different engine, such as the 2.0 TDI..!
    10
    Quote Originally Posted by Good 2 B A Gooner View Post
    I've driven both and the handling is a massive improvement over the B6, also if you’re getting a diesel the 2.0 is a much smoother, more refined drive than the 1.9.
    I was looking at the 3.0tdi, I think i'll getg the b7 if it handles better
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,533
    The engines weren't moved until the B8 - in the B7 the engines are in EXACTLY the same position as in the B6.
    Check on ETKA the engine mounts are the same between the B6 and B7.
