unless you are going mad, OEM. but if you look at your old pads they should say something on the back, imbossed into the back plate like Textar 4532 or something, just look for the textar in that material code, or who ever makes it... but tbh thats prob a bit too in depth, in which case just get them from TPS / dealer, dont be tempted by some budget pads, aas unless you know what you are looking for ie the approval numbers and material codes + brands you could get some very average pads that just pass reg90 or you could get some stonking ones.
ebc red stuffs will be ok but no real advantage over oemand could have a slightly numb feel when cold, like yellow stuff. unless you will be getting the brakes hot I would stick to either oem or poss green stuff pads, green stuff is lower dust and kinder to discs BUT you must bed it right, ie give it a bit of stick but not really hammer it but like wise dont be girly with it, as green stuff bedded wrong is ok, green stuff bedded right is brill!!!
