Badger5Chris Nott
Results 1 to 10 of 10
    Richardesty's Avatar
    loves quattro
    Oct 2008
    Louth
    753
    How to get wires from the engine bay to the cabin? A4 B7
    Has anyone managed to find a route for an extra wire to go between the engine bay and the cabin?
    I can't seem to find an obvious route - any advice will be greatly appreciated.
    Rich
    27,114
    well try looking under the wiper plastic panel where the battery is(i think on b7 as my b6 s4 was) might be a rubber grommet there with spare holes to break that you could go through, the 8P has them behind the battery that comes in the cabin behind the glovebox by the heater module, make sure you seal up with sealant to stop any condensation build up.
    loves quattro
    Oct 2008
    Louth
    753
    Brilliant - thanks I'll have a look.
    Rich
    Jun 2003
    World of my own
    9,813
    The other option is to go via the ECU cover, there's usually a spare grommet on the big rubber boot going into the ECU, and then this drops down into the footwell.
    Alex Turner
    stevehall's Avatar
    Aug 2008
    Littleborough, Lancashire
    298
    ECU cover
    How do you remove the ECU cover? I guess this is the bix box on the right hand site under the wiper blades?
    I have a crack in mine and i want to change it, but i cant seem to get the old one off.. I cant get to all the torx bits
    Steve
    ___________________________
    Audi A4 Avant B7 2.0T FSi Quattro
    Done: | Ambient Light | 18" Audi RS6 Alloys | Westfalia Detachable Tow Bar & ECU | De-Egg | RNS-E | Bluetooth Kit | RS4 Anti Roll Bar | Audi Torch | Full Rear De-Badge |
    To Come: | Audi A6 3.0TDi Le Mans - When I can find the right one!|
    loves quattro
    Oct 2008
    Louth
    753
    Quote Originally Posted by stevehall View Post
    Yeah - I've never got past the back left one either.......
    Any tips people?
    stevehall's Avatar
    Aug 2008
    298
    I am going to have a go tomorrow as I have cracked mine through messing about with it, and i need to get it back fixed so its water tight...
    Steve
    stevehall's Avatar
    Aug 2008
    298
    Found a guide on the net, and app you need to remove the wiper, and then you can access all the bolts..
    I dont have the url any more, but i have the file saved - pm me your email address and i will send it.
    Steve
    loves quattro
    Oct 2008
    Louth
    753
    Hmmmm - that would make sense!
    I've also been advised that there are a couple of rubber grommets adjacent to the battery that pass through the fire wall behind the glove box - might give them a go instead.
    Rich
    loves quattro
    Oct 2008
    Louth
    753
    Well I found an even easier route - thought the Pollen Filter Housing
    Just gotta wait til dusk to show you what I've been up to
