AH FabricationsBadger5
Results 1 to 10 of 10
    Apr 2011
    Somerset
    72
    3.0tdi Quattro stability problems
    Hi everyone,
    I'm reaching out to the wealth of knowledge in this forum as I have an issue with my a4 which has only come about from a recent tyre change. Since having my MOT done at audi they changed the rear tyres for new conti contact 5, I have Pirelli rossos on the front about 2mm tread left and the car has since handled awful. When ever I put the power down hard the traction control kicks in as if I have wheelspin especially coming out of a roundabout or corner, usually 2nd or 3rd gear making the car very unstable. I initially took the car back to audi to investigate and they couldn't find a problem but 1month later I can't stand it any more. I never had this issue before the change and basically wanted to know if it's a tyre issue (need 4 tyres the same) or a possible Quattro issue and a coincidence it happened at the same time.
    cheers
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    Personally, I'd always change the tyres on a quattro in full sets of four, and the same tyre all round.
    Also, if your front tyres only have 2mm left, I would question whether it's worth still using them. They might be legal, but they'll be all but useless.
    Get a new pair of Contis on the front, the same as you have had fitted at the back, and I'd be very surprised if you still have any problems.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Jun 2013
    255
    Agree ^^^^^^^^ set of four should be fitted, very surprised your dealer didn't tell you that but what do they know !!!!!!
    Four wheel drive requires all for wheels to turn the same circumference, put two new on one axle and you've b***xed the system up even putting four brand new on but different makes on the front and back will cause problems.
    Apr 2011
    Somerset
    72
    Okay that's great thanks for the feedback, I did wonder if that was the case but new to quattro I weren't sure, next payslip ill put some on and see how it goes.
    Sticking with the quattro system, is it normal to always hear tyres scrubbing at low speeds for example if I reverse out a parking space and change direction you can feel/hear what only can be described as the tyres scrubbing the floor as if the quattro diff is not allowing the tyres to turn freely?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    Quote Originally Posted by ollie86rn View Post
    Yes, that's normal.
    Apr 2011
    Somerset
    72
    Okay thought as much, since this tyre problem ive been listening out for all strange noises thanks jdp1962
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    You're welcome. Once you've got the new front tyres on, spend another £80 or so, and get a full four-wheel alignment check carried out. Don't use Kwik-Fit or similar; go to a Hunter & Beam-equipped specialist.
    Oct 2013
    373
    If old tyres have worn nice and flat and even, wheel alignment could be a waste of money.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    Quote Originally Posted by lynallbel View Post
    True.
    Oct 2013
    373
    If you do need to get it aligned I can highly recommend wheels in motion, oxford way, the utter dogs bollacks.
    Drove there in my skittish merc drove home at any speed you can imagine dead straight and true.
    Conversely place in essex did wifes old merc, never felt right before or after, the only car we have owned that I never found out the true top speed!
  1. 2.8 30v Quattro Engine problem
    By Hairy Ballbag in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th May 2007, 10:23
  2. A4 B7 2.0tdi Quattro
    By braes in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th April 2006, 23:56
  3. 2000 A6 2.8 Quattro engine problem
    By bullcell in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th August 2005, 23:02
  4. a6 quattro tiptronic problems
    By imported_djockey4u in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 16th July 2004, 22:45
  5. A4 Quattro Gearbox problems
    By pf9911 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th May 2004, 20:03
