Sky InsuranceChris Nott
Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By desertstorm
  • 1 Post By lynallbel
Thread: 3.0 TDI QUATTRO DIED / WONT START. HELP BROWN PANTS TIME
    Aug 2013
    Afternoon All
    right so i have a very lovely 3.0 tdi quatto avant, 55 plate 204 bhp manual.
    driving to work, and get beep, flashing coil light, engine died, no vault code, and wont start.
    the car turn over and have power, just wont start.
    any suggestions will be very helpful.
    V6 Quatt's Avatar
    Feb 2008
    783
    You need to get a machine on it to scan
    Torque the Torque
    Aug 2013
    i have tried two cheaper scanners, one i have and second that the break down service had, and now tried a third at a good indi am motors in ilminster, and still no fault codes to scan/read. and still non starter ....
    the joys of cars.
    Nov 2013
    Heath Hayes
    951
    If you have no fault codes I would suggest a fuel problem. Take the fuel pipe off that comes from the tank and make sure there is fuel coming through when the ignition is turned on. The pump in the tank should run for a few seconds to prime the circuit.
    Karl.
    Karls 312bhp A4 3.0 TDI build thread http://www.audi-sport.net/vb/audi-s4...ld-thread.html
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    822
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    You tried a proper VCDS scan? I can almost gurantee you will find a fault code if the engine isn't starting.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    Oct 2013
    373
    Check the high pressure belt is still intact, right at the front top of the V under the cover, cover looks like normal car cambelt cover, no pressure = no go, it drives of one of the camshafts on the passenger side head
    Audi A4 8E 04>08 3.0 Diesel, Injection Pump Timing Belt | eBay
    Oct 2013
    373
    Aug 2013
    Quote Originally Posted by lynallbel View Post
    SPOT ON, WAS THE TENSIONER THAT HAD GIVEN OUT, SO WOULDNT START AND SO WOULD NOT GIVE A FAULT CODE.
    THANKS FOR THE HELP.
    Nov 2013
    Heath Hayes
    951
    Your the second person in a week who has had issues with the fuel pump belt drive.
    Karl.
    jabba likes this.
    Oct 2013
    373
    Note to self get wifeys changed asap!
    Still look on the bright side its a relatively simple and cheap fix.
    Anyone know the change interval?
    jabba likes this.
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    822
    x2 Not really ever heard of this issue until now.
  1. Replies: 11
    Last Post: 15th November 2009, 20:01
  2. A6 2.5tdi Quattro(1999) wont start
    By Gnasher in forum Diesel forum
    Last Post: 7th July 2009, 15:17
  3. HELP! - 2004 Audi A4 1.8t Quattro (B6) wont start!!!
    By skyline-sl in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th June 2009, 00:50
  4. S4 B5 keeps dieing / wont start, help
    By Sayre in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th December 2006, 21:03
  5. Replies: 3
    Last Post: 30th May 2006, 19:44
